What type of driving do you do?Pennzoil Platinum or Mobil 1. Both 0w20. Mileage varied from about 7500-10,000 miles per OCI.
I have a Honda HRV that gets short tripped mercilessly. The Honda maintenance minder hits 20% oil life remaining at about 3500 miles and that's when it gets changed. Any Honda that is 6 years old with only 18k miles, and is badly sludged, has probably had the maintenance minder reset repeatedly without having the oil changed. I previously owned an Accord that would hit 20% oil life remaining at around 10k-11k miles but that car was driven 300-400 miles every time the key was turned.
I don't believe they do but I could be wrong. As far as I know, it's just some verbiage in the owners manual that says if the MM hasn't called for an oil change by the one year mark, change it anyway.Does Honda program time limits into the MM? That is, if you don't drive it much, will the light come on after a year?
GM started programming hard time limits into their OLM recently (1 year max for most cars, 2 years for the Volt)
Do you think it's possible for the light to have not come on at all in the OP's case?![]()
I'm assuming you mean the sludged engine in the video? I suppose anything is possible. That's probably the reason for the verbiage in the manual that says to change at one year regardless.Do you think it's possible for the light to have not come on at all in the OP's case?![]()
At 35 seconds into the video, the tech says the oil life minder "has probably been reset about 5 times".In the video the tech checks the oil life remaining. 70%. It would appear that it has been reset.
Yeah I wonder how he figured that to be honest.At 35 seconds into the video, the tech says the oil life minder "has probably been reset about 5 times".
I can confirm it does not factor time into the MM.I don't believe they do but I could be wrong. As far as I know, it's just some verbiage in the owners manual that says if the MM hasn't called for an oil change by the one year mark, change it anyway.
7 miles round-trip to work and back. With occasional 250 mile highway trips every few months. Nothing unusual. Oh, on some (maybe about 1/3?) of those OCI's I did not change the oil filter, as per the manual suggestion.What type of driving do you do?
That’s a nice testament to using M1 0W30 ESP . I have the first fill of it in my Hyundai 2.4L GDI engine at about 2,000 miles now on the 0W30 ESP (not sure yet what OCI I will use) .These are run on M1 ESP 0w30.
That's a very good looking engine for that many miles. Quite impressive.2014 Honda K24, with oil changed at 10-15% life remaining according to the MM. Here's what it looked like under the valve cover at 122,418 miles.
The K24 is a good engine. Kudos to the engineers...That's a very good looking engine for that many miles. Quite impressive.
Don't forget it's little brother, the K20.The K24 is a good engine. Kudos to the engineers...
If you change your oil at 5000 miles you will be fine. Modern synthetics like you said can only be trusted out to 10,000 miles under certain conditions.
If you want to keep your car for a long time forget about the Honda OLM and just do a 5000-mile OCI. With the price of a UOA and there are a few companies out there, the cost is better spent on just doing a 5000-mile OCI.
