Correct answer.What 0W-16 are you using?....... NONE!
How do you say that after the non cafe constrained material from other markets with the exact same engine is posted before you commented?I would just be worried about the variable volume oil pump. It was designed for 0w16 to be used, and for 0W20 to be used if absolutely necessary (and only for one oil change interval). I’m suspecting that it detects how much oil is being pumped, adapts to what the engine needs, and sends more. I don’t want the sensors to think oil has been sent in a certain volume when it hasn’t.
Everything in my signature has a 0W20 fill cap …I service a friend's gorgeous RAV4 hybrid using M1 0w16. I am beginning to wonder about these water oils after I accidentally dumped 5w30 into our GS350 which calls for 0w20. Dang thing seems to love the heavier viscosity.
The oil pump being designed for 0W16 theory has been debunked on here long ago. You’ll have to search to find the threads, but they are out there. It’s one of those things that was a moving target. First the oil pump was electric and calibrated specifically for 16. Then once it was discovered it was mechanical then it was a different oil pump based on the region. Then the ECU was calibrated differently. Every time something was debunked and new info was released then the goal post shifted. Bottom line is that it is not designed specifically for 16, but it is designed to allow for the use of 16. Big difference. Here is some additional info on Toyota engines.I would just be worried about the variable volume oil pump. It was designed for 0w16 to be used, and for 0W20 to be used if absolutely necessary (and only for one oil change interval). I’m suspecting that it detects how much oil is being pumped, adapts to what the engine needs, and sends more. I don’t want the sensors to think oil has been sent in a certain volume when it hasn’t.
The Internet garbage that just won't die, and here it is again in all the glory.The oil pump being designed for 0W16 theory has been debunked on here long ago. You’ll have to search to find the threads, but they are out there. It’s one of those things that was a moving target. First the oil pump was electric and calibrated specifically for 16. Then once it was discovered it was mechanical then it was a different oil pump based on the region. Then the ECU was calibrated differently. Every time something was debunked and new info was released then the goal post shifted. Bottom line is that it is not designed specifically for 16, but it is designed to allow for the use of 16. Big difference. Here is some additional info on Toyota engines.
https://toyota-club.net/files/faq/18-03-20_faq_df_r4_eng.htm#A25A-FKS
Most of the 0W16's are fairly similar in viscosity, but I have noticed that some are creeping up into the 0W20 range. Yes, I'm looking at you, Amsoil SS.List of oils I’ve used between current and previous Toyotas spec’ing 0W16.
Toyota Genuine Motor Oil 0W16
Valvoline Advanced 0W16
Pennzoil Platinum 0W16
Mobil1 AFE 0W16
Pennzoil Platinum 0W20
I cannot tell the difference between any of them to be honest. Maybe one is louder than the other and I just didn’t notice. The question is does it actually matter?
Next up is Castrol Edge 0W20 cause it was on sale awhile back. I just buy whatever is readily available and/or on sale at the time. Some times rebates play into it. But sound never does.
Have a look at this Australian manual for the 2022 RAV4 Hybrid.
Multiple viscosities are allowed up to 10W-30, 0W-16 is recommended.
It's all a fuel economy play, minuscule as it may be.
https://toyotamanuals.com.au/docs/rav4-hybrid-owners-manual-oct-22-current/
The one I posted was a uk manual and it showed up to 15w-40 and that's not wild. The prior gen allowed 0w-20 to 20w-50 so the same 3 thicker grade allowance. But a 30 grade is plenty thick and 40 grade is unnecessary unless being driven hard. Try something like m1 esp 0w-30, pp euro L 5w-30 or just m1/castrol EP 5w-30.I guess I'm going to start using 5W-30 in my wife's RAV4.
I googled the Australian manual for my wife's 23 rav4 after I saw your Pic. It only mentions up to 10W30. Japan definitely isn't changing bearing clearances for different countries.The one I posted was a uk manual and it showed up to 15w-40 and that's not wild. The prior gen allowed 0w-20 to 20w-50 so the same 3 thicker grade allowance. But a 30 grade is plenty thick and 40 grade is unnecessary unless being driven hard. Try something like m1 esp 0w-30, pp euro L 5w-30 or just m1/castrol EP 5w-30.
Gerotor pumps are. Like the crank driven ones on the LSCurious, is there a such thing as Variable Volume Oil Pump? I always hear about PD Pump ... but I typically don't visit 0W-16 or thinner threads.
Probably a revision or something. That 2023 engine hasn't changed since it debuted in 2017. Even so a 30 grade is still thick enough for it. I posted a thread of the latest yaris hybrid using the latest engine architecture which is a bit newer than yours and also uses 0w-8 but allows 16, 20, and 30 grade so also a 3 grade thicker allowance and that seems to be the real limit.I googled the Australian manual for my wife's 23 rav4 after I saw your Pic. It only mentions up to 10W30. Japan definitely isn't changing bearing clearances for different countries.
Because you got permission from Australian owner's manual???I guess I'm going to start using 5W-30 in my wife's RAV4.
No “permission” is needed. Grades listed in the manual are recommendations. As long as a minimum HT/HS is maintained you can use any grade as far as that goes. Other oil properties apply (such as SAPS level) but a higher grade of oil does not require permission.Because you got permission from Australian owner's manual???
I was waiting for the part about the drive gear in danger of being sheared off by the thicker oi
No “permission” is needed. Grades listed in the manual are recommendations. As long as a minimum HT/HS is maintained, and you can use any grade as far as that goes. Other oil p
No “permission” is needed. Grades listed in the manual are recommendations. As long as a minimum HT/HS is maintained, and you can use any grade as far as that goes. Other oil properties apply (such as SAPS level) but a higher grade of oil does not require permission.
Toyota's manuals are persnickety, and they are pushing the use of the 0W16 oils. Nobody has yet to show that thinner oils have led to engine failure or engine damage. Taking anything from a manual distributed on the other side of the planet over what you got with your car makes is illogical. Like you, I am driving older cars, but if I were to drop $70k on a spanking new Land Cruiser - which I may -- you can bet your bottom dollar that I will be following the owner's manual to the letter.... except that I will go for shorter OCI's.No “permission” is needed. Grades listed in the manual are recommendations. As long as a minimum HT/HS is maintained, and you can use any grade as far as that goes. Other oil properties apply (such as SAPS level) but a higher grade of oil does not require permission.
