"all [M1 samples] break down one [viscosity] grade due to HTHS after having beenThat statement makes absolutely no sense, would you like to revise it?
Only took a couple reads for me to figure this out, but I'm an
You realize that HTHS (viscosity) is a defined property or characteristic of a lubricant, like KV100 or VI, derived from a specific test protocol, right?"all [M1 samples] break down one [viscosity] grade due to HTHS after having beenrun[tested]"
Only took a couple reads for me to figure this out, but I'm anmoil noob.
No, because I literally just said above that I'm a noob.You realize that HTHS (viscosity) is a defined property or characteristic of a lubricant, like KV100 or VI, derived from a specific test protocol, right?
You haven't watched the video. These tests were performed in HPL's lab on several viscosities of Mobil 1 along with Castrol Edge and other bespoke blends HPL formulated for this viscosity test. Do you trust HPL testing was up to industry standards?You realize that HTHS (viscosity) is a defined property or characteristic of a lubricant, like KV100 or VI, derived from a specific test protocol, right?
So, now that you are enlightened, do you appreciate how the statement makes no sense?No, because I literally just said above that I'm a noob.
Dude, screenshots from the video were posted a few posts up from your first post in this thread, do you think we haven't been discussing this video on here before your arrival?You haven't watched the video. These tests were performed in HPL's lab on several viscosities of Mobil 1 along with Castrol Edge and other bespoke blends HPL formulated for this viscosity test. Do you trust HPL testing was up to industry standards?
I did take a look. He’s talking about FS 0w40 and 5w50. Those are not in the ESP line. In fact the pre SP FS 0w40 was tested by HPL and Dave said it was the best OTC oil they’ve tested. ESP uses that original GTL/PAO/Ester formula.In LSJr's video, Viscosity Breakdown: The Silent Engine Killer Revealed!, starting at time stamp 16:20-ish, he talks about the testing they did at HPL's lab and the thousands of Mobil 1s' samples he's analyzed, all break down one grade due to HTHS after having been run. Watch the whole video to see the actual testing prior to his presenting the results.
It affects both viscosity and the balance of the complex chemistry involved.So what SAE characteristic(s) does fuel dilution affect?
Not the answer I was hoping for. If not HTHS as @OVERKILL stated, then what specific SAE spec does fuel dilution alter to go down a grade?It affects both viscosity and the balance of the complex chemistry involved.
I will let others of more chops answer. OVERKILL is highest level. Most oil experts throw up their arms about fuel dilution. The best solutions involve increased viscosity or more frequent oil changes. Of course a lot of SAE specs are influenced by weakened or altered chemistry.Not the answer I was hoping for. If not HTHS as @OVERKILL stated, then what specific SAE spec does fuel dilution alter to go down a grade?
You mention viscosity, but isn’t HTHS (viscosity)? Or not mutually inclusive?
Fuel's interaction with the lubricant is complex. It directly reduces kinematic viscosity, as one would expect, but as @DirectRejection noted, can also impact the chemistry, such as degrading the VII polymers that boost KV as well the PPD's that prevent wax formation at low temperatures and may also reduce the effectiveness of various components of the additive package.So what SAE characteristic(s) does fuel dilution affect?
Then perhaps refrain from posting about things you don’t understand.No, because I literally just said above that I'm a noob.
Because people call out error here rather than just laud YouTube personalities?I did an internet search for "friendliest place on earth" and didn't see a single return for BITOG. I wonder why?
And is it only an error when it differs from your understanding of a given subject? Are others not allowed to have an opinion which may differ from yours, and they could be totally wrong? Or is it better you show your "expertise", not by trying to educate, but ridicule?Because people call out error here rather than just laud YouTube personalities?
Again, not singling you out, but you have to appreciate that this forum has been around for over 20 years, and its focus is, as the name would imply, lubricants and tribology. We have had many Tribologists as regular contributors on here over the years, we still have @MolaKule who posts regularly, the rest don't post as much anymore. As one would expect, with a forum focused on lubricants and tribology, we discuss lubricants and tribology pretty regularly.And is it only an error when it differs from your understanding of a given subject? Are others not allowed to have an opinion which may differ from yours, and they could be totally wrong? Or is it better you show your "expertise", not by trying to educate, but ridicule?
Unfortunately, it doesn’t show in portrait view on mobile browser. On mobile, it will show when the phone is positioned landscape.below my username that I've been here for 17 years and have over 60,000 posts
Believe it.I know at least a little bit about the subjects at hand
