edyvw
$50 site donor 2025
They are known to fail at 60k or 100k. There are some with 150k. Everything depends on exploitation. ECU drives pump depending on driving situation. City? Higher rpms. Hwy? Lower or not at all (thermostat is also electronically controlled).70,000 miles is pretty short for a water pump. I would expect better than that.
But if you like to push car, they are best thing. On 335 you can actually code desired temperature at certain driving parameters. They are really not expensive, but labor is, as they are located below. If it is xDrive, it is more labor intensive.
