VW508.00 oil change candy, dealer oil change kit w/price and part#s
Originally Posted by The Critic
I haven't tried, but is there any reason why the o-ring cannot be replaced with an OTC o-ring (from your typical HF kit)? I know VW considers it to be a one-time use part, but I think this is due to the o-ring.
I can't think of any reason that wouldn't work (keep in mind, I think a proper-fitted screw driver would still not damage the plug to a degree that would really harm the slot).
That said, I think I'm done pulling the drain plug. I've use an extractor before and still gotten out 6 qts. I use a lighted inspection mirror to do a quick check of the underside. With the oil filter up top, using an extractor just makes sense, particularly if you'd added a bigger skid plate (or you have an Alltrack with the bigger tray stock).
