I will start by saying that I am used to doing transmission fluid drain and fills on Hondas, which quite frankly are easier than an oil change. Performing this service on our VW on the other hand is foreign to me, so know that going into this conversation
I intend on purchasing this kit from ECS >>> Transmission fluid pump, as well as OEM fluid (though I am not sure how much to purchase) as information on fluid changes for the VW 09S (8 speed auto) is VERY limited from what I can find.
I do have a few questions that I hope some of you might be able to shed some light on. I am reading that the car needs to be level to perform this service, as well as having the transmission fluid temp between 35-45 celsius. My primary questions are #1, can this service be performed using ramps (on front wheels only), and #2 would it be safe to assume that as long as I measure the volume of transmission fluid that comes out COLD, I could simply add the same amount back without fussing with having the car level, and at a certain temp?
I'd like to do a drain and fill on this transmission at 10K then every 20K thereafter if I can perform this service myself. If I end up having to pay the dealer I'd likely have it done every 30K. Sooner is better in my book so DIY is preferable as the cost savings should be appreciable.
OH TO HAVE A DIPSTICK! haha.
