You sound like another poster on here who was taught a lot of things that have no basis in fact.I've been taught from alot of people that cast iron engines were designed for thicker oils
And 508.00 is not designed for GDI engines?
Its an oil specification that is used to help with fuel emissions, it only increases mpg by not too much, if your car is under warranty still I would recommend still using 0w20, but please don't go riding rough or letting the tachometer go above 3,000 rpm, Volkswagen still uses cast iron blocks and from what i've been taught and seen is that the tsi does not have a higher pressure oil pump to help sling the oil aggressively when thinner engine oils are used.
After warranty, I would recommend using a 5w30 or 5w40. Cast iron blocks were used for thicker oils in mind, but since your engine is equipped with a turbocharger I would avoid using a straight grade or above 15w40. keeping it a 5w40 is perfect after warranty, I don't want your engine getting worn out in the name of fuel efficiency.
ANd how does that exactly works?I've been taught from alot of people that cast iron engines were designed for thicker oils
VW 508 is available from the dealers for 6 bucks a quart, and can be had for less elsewhere. I'm not aware of any oil, much less a top tier synthetic you can buy at Wally's for 2 bucks a quart.It is, just the triple the price of GDI oil you can get at Walmart.
If you want a great, great GDI oil, get: https://www.amazon.com/Idemitsu-Syn...mitsu+0w20&qid=1616800399&s=automotive&sr=1-1. It's what the Japanese cars come with... and those are the cars that last for g'dam ever, not VWs.
I don't know about being baseless but i've only ran thick oil in cast iron engines and they never have diedYou sound like another poster on here who was taught a lot of things that have no basis in fact.
And how do you know running thin oil wouldn't have produced the same result? Confirmation bias.I don't know about being baseless but i've only ran thick oil in cast iron engines and they never have died
Nice. That’s it then.I don't know about being baseless but i've only ran thick oil in cast iron engines and they never have died
The Idemitsu oil you linked is over 7 bucks a quart.
I am just asking bcs. I worked on development of oils that are approved by VW, and it is not at all what you assuming. You make an assumption based on the fact that you can buy oil in Wal Mart that is 0W20 and somehow it is same thing as VW approved oil. Also, your assumption is from get go flawed as you put all GDI engines as same.It is, just the triple the price of GDI oil you can get at Walmart. The VW oil is designed for a 10,000 service interval and is colored green so VW can deny engine failure warranty claims. If you are changing at 5,000 miles the VW oil is overkill and a waste of money. You can use it, sure. If you want a great, great GDI oil, get: https://www.amazon.com/Idemitsu-Syn...mitsu+0w20&qid=1616800399&s=automotive&sr=1-1. It's what the Japanese cars come with... and those are the cars that last for g'dam ever, not VWs.
Since we have absolute proof here about effectiveness of thick oils, I want apology from all you thin oil loversNice. That’s it then.
I don't see where he stated the Walmart and VW 0w20 are the same. He's arguing that if changing at 5K miles, you can use a Synthetic 0w20 sold at Walmart.I am just asking bcs. I worked on development of oils that are approved by VW, and it is not at all what you assuming. You make an assumption based on the fact that you can buy oil in Wal Mart that is 0W20 and somehow it is same thing as VW approved oil. Also, your assumption is from get go flawed as you put all GDI engines as same.
by the way, there are numerous oils in Wal Mart that are approved for European vehicles and not any more expensive than your “oil for GDI engines.”
VW508.00/509.00 doesn’t only mean longer OCI. There are other aspects of approval that are more stringent than your average ILSAC GF6 or whatever. When it comes to European approvals, “I will cut OCI in half” doesn’t work. Certain OCI is just one of the requirements.I don't see where he stated the Walmart and VW 0w20 are the same. He's arguing that if changing at 5K miles, you can use a Synthetic 0w20 sold at Walmart.
They are, nothing stops them to get VW approval.We all know 508.00 is quality a product but so are many ILSAC/SP oils out there.
The VW 508 oils are not backward compatible. In the words of one well known oil producer "May not provide adequate protection in engins not specifying VW 504". This in itself makes me question the superiority of this wonder lubricant.Cost aside...would there be any benefit in running a VW 508 oil in a Japanese, Korean or American made engine designed for 0w20 (or 5w20)?
The lubricant is IMO superior to other 0W20 lubricants (with exception of MB 229.71, BMW LL14, 17).The VW 508 oils are not backward compatible. In the words of one well known oil producer "May not provide adequate protection in engins not specifying VW 504". This in itself makes me question the superiority of this wonder lubricant.
Apology is only effective face to face and if followed up with box of chocolate, candy or flowers.Since we have absolute proof here about effectiveness of thick oils, I want apology from all you thin oil lovers
