3 jugs, zero leaks
Thank you KC for your response.. but if that's the case, how come you see higher concentrations of Moly in Amsoil as well, and that's a premium product?Whenever you see Moly in the higher ppm range you can figure it’s dimer.
Trimer works really well in smaller concentrations you usually see it in premium products at around 80 ppm.
I would think any time parts are coated/wet with the oil that it would be doing something, unless it needs heat to be effective. Wonder if Valvoline Tech Support would have an answer.Does my engine have to be running for these additives to function? Or will residual oil, which has bonded to components, clean when I am tucked in bed at night?
Both types can be used but why pay the extra cost for both, if both types do the same thing? Much depends on the type of MolyDTC and as to which one balaces the formula (i.e., which one works synergistically or antagonistcally with other additive compounds) and provides sufficient friction modifcation and wear reduction.We need Dr. @MolaKule's expertise here. Can both types be effectively used at the same time? Also I'm curious why molybdenum is overall preferred over tungsten? It's a fascinating subject for sure and maybe we can get updated with some of the latest literature on this
I'll just chalk it up to happenstance, just thought it was odd was all. I'll just order from Amazon next time.
I would suspect a little of both... As someone mentioned if a component is coated, but I also would suspect that certain chemical/element reactions have a heat and time domain that has to happen for the intended reaction to take place. In this case the reaction would be various elements of your Add-Pak working as intended.Does my engine have to be running for these additives to function? Or will residual oil, which has bonded to components, clean when I am tucked in bed at night?
Agreed!People forget about the Valvoline product in the red bottle called Maxlife ATF, which is a pretty darn good product IMHO.
I wish I did not have such a large stash, I would use it. I may buy a jug a try it on the 3.7L Acura that still has varnish after 30K miles of trying every concoction in the book to see if it makes a difference.
I say More, LOL.I find myself currious about these piston deposits that R&P claims to clean. What causes them? Would a hybrid or PHEV be more or less prone to accumulating these deposits given that they run less but start and stop more?
My instincts say less, but I wouldn't have asked if were sure about that. The PHEV in my signature is two months and 1500 miles into ists current tank of gas having consumed about six gallons. Most of that consumption occured on the date of the last fill in West Virginia driving home to SE PA. Given my daily driving habbits the ICE won't start again until the next long road trip. I am not sure if Valvoline R&P would be of any benefit to me. If I follow the owner's manual the next oil change will occur in August 2025.I say More, LOL.
What bothers me the most about this oil is that there is no claim of "Guaranteed to protect for xx,xxx miles as is comon on other premium oils.
