This is what you paid for, I hope this is what you got.Shell V-power Nitro
In your experience with your job, do you have a sense of which of the top fuel brands has the best detergent package? The marketing claims all compete with each other... 4x 5x 6x etc the amount of required detergents. At some point you're going to displace fuel by the amount of detergents and lose MPG lol.The better the base fuel, the better any additive will work so the 2 would just compliment each other. All top tier fuels are going to have some detergency package to them, the question is how much. Most gasoline companies claiming cleaners add the least amount to be able to claim it, but it definitely helps keep the engine cleaner over the long term if continually using top tier detergency gasoline.
I cant give out much detail due to non-disclosure agreements, unfortunately. What I can say is our chemists work with some larger refineries to innovate top tier fuels and detergent packages and they are all slightly different... different enough that you would tell if you run one from another? Most likely not. If its top tier fuel your getting the best you can get. One may have a bit more cleaning than others, but again nothing I would say you would notice. The newest thing rolling out that you dont really see necessarily is newer more modern blending stations at the gas stations themselves putting additional detergents into the underground tanks. Seems like it may be the future of detergent packages, but we will see. Regardless the amount of cleaners in top tier fuels will never amount to the same as dumping a good quality additive in. At least not that I foresee!In your experience with your job, do you have a sense of which of the top fuel brands has the best detergent package? The marketing claims all compete with each other... 4x 5x 6x etc the amount of required detergents. At some point you're going to displace fuel by the amount of detergents and lose MPG lol.
Yeah it seems like getting Costco gas and using the savings to use a fuel system cleaner every OCI is probably the best option. I'm still intrigued by Shell gas as people seem to have the best experience with it, but it's all anecdote.I cant give out much detail due to non-disclosure agreements, unfortunately. What I can say is our chemists work with some larger refineries to innovate top tier fuels and detergent packages and they are all slightly different... different enough that you would tell if you run one from another? Most likely not. If its top tier fuel your getting the best you can get. One may have a bit more cleaning than others, but again nothing I would say you would notice. The newest thing rolling out that you dont really see necessarily is newer more modern blending stations at the gas stations themselves putting additional detergents into the underground tanks. Seems like it may be the future of detergent packages, but we will see. Regardless the amount of cleaners in top tier fuels will never amount to the same as dumping a good quality additive in. At least not that I foresee!
If you’re using Costco gas then you don’t need any additional cleaners. Costco has almost as much detergents as Shell V Power. I have never used any fuel additives in my Civic and I mostly use Costco gas.Yeah it seems like getting Costco gas and using the savings to use a fuel system cleaner every OCI is probably the best option. I'm still intrigued by Shell gas as people seem to have the best experience with it, but it's all anecdote.
Well perhaps if you had it since new. I bought it used. No idea what it was run on before I had it.If you’re using Costco gas then you don’t need any additional cleaners. Costco has almost as much detergents as Shell V Power. I have never used any fuel additives in my Civic and I mostly use Costco gas.
I haven’t had mine since new. I bought it 5 years ago with 130,000 km on it and now have 301,000 km. I’m not sure if the previous owner ever used anything but even if they didn’t, Costco gas has enough cleaning ability to reduce that buildup, just like Shell V Power does.Well perhaps if you had it since new. I bought it used. No idea what it was run on before I had it.
In town mpg is up and it seems more responsive off idle. Nothing conclusive just yet.What have you noticed?
Hopefully not the same issues as NYC since I’m at least 1 hour away from there. I’m sure that it is probably more rampant then anyone realizes, who knows.This is what you paid for, I hope this is what you got.![]()
I’m not sure if “most detergent” is an actual measure of effectiveness inside of an engine … considering both Exxon and Shell have additive packages developed by serious R&D teams … I’m sticking with themYeah it seems like getting Costco gas and using the savings to use a fuel system cleaner every OCI is probably the best option. I'm still intrigued by Shell gas as people seem to have the best experience with it, but it's all anecdote.
I’m sure that the people who developed the additive package for Costco’s gasoline are just as talented as the ones who did it for Exxon and Shell. It’s entirely possible that they’re the same people.I’m not sure if “most detergent” is an actual measure of effectiveness inside of an engine … considering both Exxon and Shell have additive packages developed by serious R&D teams … I’m sticking with them
You are sure?I’m sure that the people who developed the additive package for Costco’s gasoline are just as talented as the ones who did it for Exxon and Shell. It’s entirely possible that they’re the same people.
Costco is not an oil or chemical company. So who would they turn to for development of their fuel additive package? Probably Sopus, Exxon Mobil, or Chevron or one of their subsidiaries. If they want to be the best, those would be the primary choices, in my opinion.You are sure?
I’m sure they don’t have four digits in PhD headcount’s …
I would think just whomever they buy from. They can all buy from BASF etc …Costco is not an oil or chemical company. So who would they turn to for development of their fuel additive package? Probably Sopus, Exxon Mobil, or Chevron or one of their subsidiaries. If they want to be the best, those would be the primary choices, in my opinion.
It usually comes down to economics and bean counting, not intellectual prowess.You are sure?
Actually the sharpest chemists do more with less …It usually comes down to economics and bean counting, not intellectual prowess.
NO amount of talent at the big branded stations is going to make them use an additive that is very costly, regardless how miraculously effective it may be.
That said, I use V-power or Synergy only. So there's that.
COSTCO Premium exclusively may work in some models for 5 plus years. Most vehicles can benefit from PEA infused additives every oil change. I'm testing Valvoline Restore and Protect fuel system treatment in both cars. They are running great, may have more responsive throttle when floored. Will be interesting to learn what chemicals Valvoline Restore and Protect used in the fuel treatment.If you’re using Costco gas then you don’t need any additional cleaners. Costco has almost as much detergents as Shell V Power. I have never used any fuel additives in my Civic and I mostly use Costco gas.
