- Joined
- May 16, 2022
- Messages
- 867
Anyone who grew up in the 70's or 80's will remember the inexpensive STP Gas treatment thats still made today with instructions that state
"Use regularly when you fill up your tank". I always had my doubt if gas treatments did anything except part me and my money.
Now we have the strong stuff with PEA based cleaners that I guess you can say are proven to work as we all have seen the Youtube videos showing carbon removal and better F.I. spray patterns. The instructions on all the PEA cleaners I have seen suggest use every 3K. 5K or even 10K.
Okay, if you are with me this far, I choose to use a Ethanol free 100% gas 93 octane in my motorcycles, toys, lawn mowers.
Its good running gas but no name and I would assume as far from Top Tier gas as one can get.
Also, in my area the once Top Tier stations have all recently changed branding and all gone no name budget gas...
I question IS a gas treatment available that would essentially "boost" the minimum required by law additives to something similar to Top Tier gas?
If not, I question the snake oil gods ( manufacture ) why not?
I'm not sure If true but I have seen it posted and suggested that gas companies or even the truck driver will blend the additives at the regional hub before delivery? If thats true, I should be able to buy something similar in a bottle from Walmart to boost my no name gas to a better grade but not something strong enough that I can't use it but once every 3K+ miles like ALL the PEA cleaners I have seen.
All I know is IF I could buy a bottle that the label said something like " Will Boost your gas cleaning power to that of top brands"
and then a "safe to use every fill up". I would buy a bottle every fill up!
So Chevron uses Techron in its pump gas that one can use every day but If I by a bottle of Techron I'm told...
Techron Complete Fuel System Cleaner is recommended for use every season (winter, fall, spring, summer) or right before an oil change with no more than two treatments between oil changes.
To me the idea to use a cleaner in every tank to keep things clean must be better than cleaning in one tank every oil change 3K -5K miles after things start to get dirty right?
Does a product exist that will actually clean or keep things clean like Top Tier gas claims but I can use in every tank of gas for every day driving?
