Sure… The definition of hydrodynamic portion of the Stribeck curve. Should I have said “bearing separation by the oil” for you.Oil separation?
In this case, it may take a while for a failure to happen. Way to low HTHS viscosity will cause more wear, there's no question there. For instance, if the journal bearings wear to a certain degree, it's possible one of them could get to a point where it goes downhill fast ("eats itself"), locks-up enough to spin and possibly throw a rod like @OVERKILL mentioned. But I'm thinking this test vehicle won't be driven hard enough or long enough to see that happen sooner than later, or maybe never depending on use conditions, and will just have much more bearing and engine wear as a minimum.Well… If there is RPM on the engine the oil is pumping and the bearings are in hydrodynamic portion of the Stribeck curve. Cold start 0w-5 is the same viscosity as what you have in your car when you start it when cold. There is oil separation and the engine will not blow up. The 5 viscosity is at 212 F oil temperature whatever cSt that is. The engine made it there without catastrophic failure.
But if the oil volume gets there it doesn't mean there's adequate lubrication. The other parts of adequate lubrication is proper MOFT (film thickness) to keep moving parts adequately separated, and a good AF/AW tribofilm (film strength). At least super thin oils like 0W-8 and below have more AF/AW additives which they need to help take over the wear protection when the MOFT starts to fail doing its main goal.Fluid is not compressible to an oil pump, all viscosity oil pumps the same as a positive displacement until the pump goes into bypass.
Part of keeping that MOFT wedge adequate is the oil viscosity. Too low viscosity can result in zero MOFT, causing wear and damage. Thought that was pretty much known by any constant reader of this forum because it's discussed almost daily, lol.Sure… The definition of hydrodynamic portion of the Stribeck curve. Should I have said “bearing separation by the oil” for you.
Which is the main problem with a test like this. An OEM would test for hundreds of thousands of miles under various loads and environmental conditions and then rinse/repeat until there is a large enough sample base to establish a true repeatable result.But I'm thinking this test vehicle won't be driven hard enough or long enough to see that happen sooner than later, or maybe never depending on use conditions, and will just have much more bearing and engine wear as a minimum.
Beat me to it--these are the points that are missing in the conversation. Thanks Zee.Part of keeping that MOFT wedge adequate is the oil viscosity. Too low viscosity can result in zero MOFT, causing wear and damage. Thought that was pretty much known by any constant reader of this forum because it's discussed almost daily, lol.
Those are the basic working points of Tribology and how oil keeps moving parts from wearing, and it's been mentioned over and over by many members here, but seems that it goes unabsorbed by many.Beat me to it--these are the points that are missing in the conversation. Thanks Zee.
That's all and fine and dandy as long as the oil doesn't leak out of the bearings first.Part of keeping that MOFT wedge adequate is the oil viscosity. Too low viscosity can result in zero MOFT, causing wear and damage. Thought that was pretty much known by any constant reader of this forum because it's discussed almost daily, lol.
Proper hydrodynamic bearing lubrication (ie, an adequate MOFT to prevent wear) requires a minimum viscosity ... journal bearing lubrication is viscosity dependant. Too low a HTHS viscosity and bearings can start to wear and become damaged. The Sribeck curve has nothing to do with the MOFT in bearings due to the many factors involved - HTHS viscosity, RPM, oil pump feed pressure, bearing oil flow rate, bearing clearance, oil temperature rise inside the bearing.Well… If there is RPM on the engine the oil is pumping and the bearings are in hydrodynamic portion of the Stribeck curve. Cold start 0w-5 is the same viscosity as what you have in your car when you start it when cold. There is oil separation and the engine will not blow up. The 5 viscosity is at 212 F oil temperature whatever cSt that is. The engine made it there without catastrophic failure.
Don't have to as long as you're using the 10W in the climate a 10W is rated for.Imagine using 10w-60 in your car that you had to pre heat before starting.
Well, if each oil filter cup open and inspection shows increasing metal debris then I'd say that's an indication that things aren't going well. A UOA won't show major wear, like visible debris in an oil filter.So, basically, all tests without a control are useless and we can only know if it’s fine or not depending on if his engine throws a rod.
Well… They heat up the Formula 1 engine to 80 deg. C (176 F) The bearings have tighter clearances. The oil needs to thin out to match.Don't have to as long as you're using the 10W in the climate a 10W is rated for.
Lots of good engineering and well controlled scientific experiments and studies have been done on engine wear for decades ... therefore, personally I don't have to conduct my own experiments to see how something will behave. Just have to glean through all the studies to determine the overall consensus of the test results Just like I don't have to build a rocket to try and get myself high enough to "see with my own eyes" that the Earth isn't flat, lol.I don’t agree with his logic wherein something needs to be seen to be believed. I’m sure that’s a bit of an exaggeration and he’s not being literal, because I‘d be extremely concerned if that’s his philosophy for other important decisions in life. I mean, it would be insane for anyone with an actual stake in something to not use empirical data and lessons learned/best practices. Why would anyone need to prove something like this to themselves, is what I’m getting at.
MOFT is always changing with the oil temperature, and that is old news too…Part of keeping that MOFT wedge adequate is the oil viscosity. Too low viscosity can result in zero MOFT, causing wear and damage. Thought that was pretty much known by any constant reader of this forum because it's discussed almost daily, lol.
And it was explained why.Well… They heat up the Formula 1 engine to 80 deg. C (176 F) The bearings have tighter clearances. The oil needs to thin out to match.
Yep, it should be old news, but what happens when the oil gets to a temperature where the MOFT goes to zero inside a journal bearing?MOFT is always changing with the oil temperature, and that is old news too…
Well… we are talkin about some hot stuff there. Got any (hot) links?Yep, it should be old news, but what happens when the oil gets to a temperature where the MOFT goes to zero inside a journal bearing?
