- Joined
- Mar 20, 2022
- Messages
- 22
Hello folks,
I'm sure my case is unique and this kind of question has never been asked before.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a 2018 VW Golf R that has been ECU flashed to make more power and torque. Mainly I am worried about the torque aspect because when I asked for even more, people starting warning me that it is nice to keep the rods inside the engine instead of outside. OK...
Initially this car ran Castrol Edge 5W40 and 0W-40 because people on this forum said it was good. But then I started to worry about intake deposits and saw criticisms about this oil shearing down. I then switched to Mobil 1 ESP 5W-30. (Most recent oil analysis is posted in this thread where the first two OA are the Castrol Edge and the last is ESP. They ended up with nearly the same viscosity at the time of changing out)
NOW I am back to wondering if I should be running a thicker oil again, or one of those botique oils, e.g. Motul, Liqui Moly, etc.
I don't race on the track and only hit WOT for short bursts because I am a safe driver and follow all the rules of the road.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The label on the engine says VW 502 504, but I'm not sure how relevant that still is in [current year].
The maximum oil temperature I have seen is 22x F. (Uhh, wait, lemme get back to you on that one...)
I guess the highest priority at the moment is to protect the engine during these short bursts of high torque application.
