Just looking for some expert advice on which Euro ACEA A3/B4 or ACEA C3 oils with HTHS > 3.5 (5W-30 or 5W-40)
would do best in an engine with higher than normal operating temperatures. As many of you know the 3rd gen Honda J35 V6 with VCM enabled has some extreme hot spots on the front cylinder heads which is murder on the oil and requires shorter OCI's.
I'm looking for a low to medium priced Euro 5W-30/5W-40 oil that would be "best at resisting forming deposits in high heat applications".
Possible choices could be (but not limited to):
Mobil 1 ESP 5W-30
Castrol A3/B4 5W-30
Pennzoil Euro L 5W-30
Quaker State Euro 5W-40
HPL would be a good choice which I am considering, but also wanted to look at lower priced alternatives.
Thanks
Mobil 1 ESP 5W-30
Castrol A3/B4 5W-30
Thanks
