My engine prefers 0W20 over 0W16. It loves it so much. I can hear it.
In typical bitoger mentality, if more of a good thing is better, more of a non-bad thing must be in the direction of goodness too. (0w-40 in all things!)
Tolerate vs prefer vs agnostic. Either wear is present due to metal parts touching or it isn't. If it isn't, the lubricant is doing its intended job through one or more mechanisms.
Perhaps it's not all about the MFT. For example, there is a following for HPL no-vi/low-vi on bitog for a reason. Threads focusing on IVD as a aspect of oil selection do happen. If toyota figures they've achieved wear targets, are they now going after other wholistic aspects of the engine/lubricant system? (Tiny fuel economy gains being one of them?)
Even if you believe that his wear test method provides any valuable information, those results only differed by a whopping 5% I know it looks larger, more like a 2x difference between the best and worst, because of how close he zoomed in on the y-axis. A tried and true tactic of deceptive data presentation.BTW, in another recently published lubricity test by PF, Toyota-brand oil came dead last when compared to equivalent Motorcraft, ACDelco, Mopar and Mobil1 oils. Disappointing. I hoped for a better result.
Yes. Those "tests" just don't mean much. Even when Amsoil wins.Even if you believe that his wear test method provides any valuable information, those results only differed by a whopping 5% I know it looks larger, more like a 2x difference between the best and worst, because of how close he zoomed in on the y-axis. A tried and true tactic of deceptive data presentation.
Results close enough that I’d be shocked if his test setup could even reliably measure differences that small. Something he could easily prove but never has. But I get it, content needs to be churned out and why bother doing even the smallest amount of experimental rigor when it’s just so much easier to amplify potentially meaningless differences by hard ranking results as 1st 2nd and 3rd place.
hahahahahahaAnd suddenly, LSJ is BITOG's current obsession.
HPL, congrats, you had a great run.
LOL
A proper analysis of the already deeply flawed data shows that there is zero difference between any result.Even if you believe that his wear test method provides any valuable information, those results only differed by a whopping 5% I know it looks larger, more like a 2x difference between the best and worst, because of how close he zoomed in on the y-axis. A tried and true tactic of deceptive data presentation.
My viewpoint is that it's about wear protection headroom. Nobody here knows exactly how close every part inside an engine is to running at zero film thickness. But if you have more film thickness between parts to start with, then there is more film thickness to work with and therefore more wear protection regardless of the possible driving conditions. It really hurts nothing to have more separation going on between moving parts except for a little less fuel economy (CAFE's ears just perked up) that can only really be seen in a controlled laboratory test. Keeping parts separated with a lubricant's viscosity is the whole basic scheme from the begging of the science of Tribology. Obviously AF/AW additives science these days has a roll in the mitigation of wear too, but in the end the viscosity will always be the main property of a lubricant to keep parts separated from rubbing and wearing. I'd rather rely mostly on viscosity instead of the tribofilm if I have a choice.In typical bitoger mentality, if more of a good thing is better, more of a non-bad thing must be in the direction of goodness too. (0w-40 in all things!)
In the end, it's actually all about the HTHS viscosity. HPL no-VI oils have better HTHS viscosity when comparing the same SAE kinematic viscosity grades because they lack VIIs and have a stout base oil. The VIIs shear between moving parts (both temporarily and permanently), and that decreases the kinematic viscosity to a lower HTHS viscosity down the what the base oil was before VIIs were added. The HTHS viscositly is what really matters between moving parts.Perhaps it's not all about the MFT. For example, there is a following for HPL no-vi/low-vi on bitog for a reason.
I have used this kind of oil can from my grandparents to oil my bike chain... Memories! And fun to use!If my dates are correct - this style of oil can came out about when GON and Pablo started chasing girls - I have however brought new life to it with one of these modern lubes (ain’t going in my motor)
He is using his daughters '23 Corolla as test bed. Also mentioned how 10,000 mile oil changes are not a good idea and that he changed the oil twice already himself before taking it in to the dealer at 10,000 miles to see what oil they will use.
Unfortunately, most articles are AI written BS now unless it's coming from a trusted source.Remember when monetized video wasn't a thing and you could actually read articles? Now we're stuck with 30 minute videos for 3 minutes of actual content that you could have skimmed in 60 seconds if it were written text.
It's been pointed out in other threads that his "cold oil flow race" test doesn't always correlate to the CCS and MRV specs of the oils he's comparing. So those cold flow tests may not actually correlate to how those oils would actually behave in a cold start-up and pumpability in a real engine. These days, a lot of people buy into the hype based on only the visual aspects they see instead of the actual technical aspects.As far as I can see the PF methodology test viscosity.
0w16 meets GF-6B. What’s 0w8 story?
pao? Now sure why you would ask me that, I know next to nothing about those technical aspects of oil beyond weight and gradeWould a 5-40/50 pao oil be better?
