For the newer 5.0, Ford recommends 5w30 solely to try to minimize oil consumption due to the cylinder liners being applied with a plasma process. The viscosity change is not retroactive.5w-30 is the thinnest I will run. I’m going to give PUP a try next OCI. Ford no longer recommends 20 weight for these engines.
Ford recommended 5W-30 for the Mustangs in Australia (not CAFE driven) before they ever recommended it in the USA as you mentioned.For the newer 5.0, Ford recommends 5w30 solely to try to minimize oil consumption due to the cylinder liners being applied with a plasma process. The viscosity change is not retroactive.
That’s also in Australia which is a different climate, in a different vehicle that is driven differently with a different cam.Ford recommended 5W-30 for the Mustangs in Australia (not CAFE driven) before they ever recommended it in the USA as you mentioned.
The cam doesn't matter to what oil viscosity is used. People in the USA drive Mustangs just as hard, and it gets real hot here too in parts of the USA. And yes, all the journal bearing clearance specs are the same regardless of country the engine goes to. Ford specified 5W-30 because they know it's better than 5W-20 for engine protection, and they are not driven by CAFE for cars sold in Australia. Ford finally went to 5W-30 in USA Coyotes because they finally broke down and did it to work and protect better in the Coyote.That’s also in Australia which is a different climate, in a different vehicle that is driven differently with a different cam.
Sources for the statement that 5w30 protects better? I find that hard to believe as both OEMs and oil companies have independently verified that 5w20 does not equate to less protection.The cam doesn't matter to what oil viscosity it used. People in the USA drive Mustangs just as hard, and it gets real hot here too in parts of the USA. And yes, all the journal bearing clearance specs are the same regardless of country the engine goes to. Ford specified 5W-30 because they know it's better than 5W-20 for engine protection, and they are not driven by CAFE for cars sold in Australia. Ford finally went to 5W-30 in USA Coyotes because they finally broke down and did it to work and protect better in the Coyote.
Many wear studies show that less wear over the long run results with a higher viscosity (specifically the HTHS viscosity). It's been discussed here for years in many threads. The HTHS viscosity of xW-20 is near the viscosity where wear on some engine components starts to increase. Ford went to 5W-30 on the Coyote because they know it causes less wear issues. 5W-20 in the Coyote was mainly a CAFE driven recommendation. Many Coyote owners use xW-30 or even thicker oils, mostly the guys who race their cars. 5W-20 would be fine for grandma driving, but not as good for hard use conditions.Sources for the statement that 5w30 protects better? I find that hard to believe as both OEMs and oil companies have independently verified that 5w20 does not equate to less protection.
I’m not trying to be difficult, but do you have sources to support these claims? I am unaware of any studies verifying what you claim. If I’m wrong, I’m wrong, but I don’t see any sources showing that.Many wear studies show that less wear over the long run results with a higher viscosity (specifically the HTHS viscosity). It's been discussed here for years in many threads. The HTHS viscosity of xW-20 is near the viscosity where wear on some engine components starts to increase. Ford went to 5W-30 on the Coyote because they know it causes less wear issues. 5W-20 in the Coyote was mainly a CAFE driven recommendation. Many Coyote owners use xW-30 or even thicker oils, mostly the guys who race their cars. 5W-20 would be fine for grandma driving, but not as good for hard use conditions.
This has been discussed for years on this board ... with lots of technical info. Here's one, showing the effect of HTHS viscosity on piston ring wear. The HTSH of xW-20 is around 2.3 and for xW-30 it's around 3.2. Look at the wear curve at those two points on the top graph. You will have to do some back reading here and/or go do some self research on wear vs viscosity. There is lots of info on the subject.I’m not trying to be difficult, but do you have sources to support these claims? I am unaware of any studies verifying what you claim. If I’m wrong, I’m wrong, but I don’t see any sources showing that.
Right, I’ve seen a lot of the threads on it and it’s beating a dead horse. The study shown above is comparing base oils without additives and the wear difference is marginal at best. In fact, the graph shows that the HTHS of 2.3 is more optimized than the 3.2.This has been discussed for years on this board ... with lots of technical info. Here's one, showing the effect of HTHS viscosity on piston ring wear. The HTSH of xW-20 is around 2.3 and for xW-30 it's around 3.2. Look at the wear curve at those two points on the top graph. You will have to do some back reading here and/or go do some self research on wear vs viscosity. There is lots of info on the subject.
The top graph clearly shows the wear rate based on the HTHS viscosity. How is an oil with 2.3 HTHS "more optimized" over an oil with 3.2 HTHS viscosity in terms of wear. If both oil had exactly the same AW/AF package, the higher viscosity oil will result in less wear. Sure, AW/AF additives (the tribofilm, aka "film strength") help reduce wear but only after the viscosity failed to do so (the "FM effect" annotation on the top graph starting around 2.3 cP HTHS). Viscosity is always the main mitigator of wear between rubbing parts. Been that way ever since Tribology was invented well over a 100 years ago. But you can believe whatever you want.Right, I’ve seen a lot of the threads on it and it’s beating a dead horse. The study shown above is comparing base oils without additives and the wear difference is marginal at best. In fact, the graph shows that the HTHS of 2.3 is more optimized than the 3.2.
Would ESP 5w30 suit your needs?What I’m getting at is mostly the hot viscosity. It’s an interesting comparison. 0w-40 & 5w-30 are very similar. Trying to find an oil chart that is not CAFE regulated for this engine. Is a slightly thicker oil at 100c is actually better and offers more protection vs 30 weight?
My 5.0 in my 2016 f150 was a knocking POS.I realized no measurable difference in mpg in my 2015 5.0 from 5-20 to 5-30. Great engine.
Kia and Hyundai are perfect examples on how 5w20 lacked protection (2012-2019). A world of difference when switching to the 30s. Even the 0w20 is built better than 5w20s.Sources for the statement that 5w30 protects better? I find that hard to believe as both OEMs and oil companies have independently verified that 5w20 does not equate to less protection.
