HPL SuperCar 5w-40 for 2.0T Honda
No way I'm running a 40 weight oil on an engine recommending 20. 5W/0W-30 maybe. If you are worried about fuel dilution, change the oil at 6 month intervals. If you don't like getting under the car, buy an oil extractor. With changes at 5k or earlier, any API SN/SP oil is fine, even SuperTech/Kirkland. Out with the old, and in with the new, and profit.
Sigh
K20C4 is US specific, but any other K20 turbo is 30 anywhere else.
I don't know of any older K-series engines pre ca;2010 outside US that specs 20visc. But I could be wrong.
That said with turbo, temps close to piston and in the turbo is what you should be concerned about, not sump temp. IMO.
Older K series engines (K20a, k24a) are quite different from the K20C series which are natively turbocharged.
The owner’s manual excerpt above shows that even 5w-40 is within the manual for this engine in other markets when it’s used in the Civic Type R.
K20C3 China market has 10W30 in the book (y)
So, now the final challenge— which HPL 30 grade? The crazy high Calcium in the 10w20 no VII kinda of scares me for LSPI that the 30 grade no VIIs Euro oils might also have excessive calcium.
Thus far I’ve been running V Power so maybe I just stick to premium to prevent LSPI and run any Euro oil I want to get the stouter add pack?
I mean, it seems to me that if LSPI is a concern, and you’re already running 93 octane, one might as well just stick to premium fuel, consider LSPI a non-issues and run the the stout HPL oil add pack and have no worries.
Right?
I have a 2019 2.0t and have been running 0w20 but after doing research on the non cafe recommendations in Europe etc they recommended 5w30 so I’m planning on running 5w30/0w30 going forward. Figure it couldn’t hurt anything and fuel dilution is pretty common on uoas for the k20c4
Right?
Fuel octane rating has not been shown to affect the occurrence of LSPI. A couple of papers I've seen have not shown a correlation.
The specific fuel composition that is used to achieve a rating might, but even that is inconclusive. Engine design, displacement, and to a lesser extent oil are the known contributors.
I have no context that would cause this post to make sense to me. Who are you talking to? Who’s talking about restoring an engine with 21k miles on it?
Your very first sentence on your very first post?
Just acquired a 2.0T Honda Accord with only 20k miles on it. I drained the oil as received to run a change of VRP 5w30 to clean out any deposit nucleation that might have started already. This initial ODI gives me some time to ponder long term strategy.
1) You acquired a Honda with 20k miles
2) you drained oil to run a change of VRP to clean out deposit
3) you now have no idea how talking about not needing to remove any deposits on a 20k mile engine has anything to do with your post about removing deposits on a 20k engine? Unless you’re trying to say removing deposits isn’t the same as restoring which , I mean, it’s one and the same and even the name of the R in the VRP you specifically speak about.
That doesn’t make any sense to you at all to directly reply to your post on your own topic? Nothing rings a bell?
