No engine requires it.I don’t know if I want to drive a vehicle with a “ice” requiring oil that thin. I’d be comfortable making the transition to an ev by then.
Also known as a county fair demonstration. Many useless things get promoted this way.It's been pointed out in other threads that his "cold oil flow race" test doesn't always correlate to the CCS and MRV specs of the oils he's comparing. So those cold flow tests may not actually correlate to how those oils would actually behave in a cold start-up and pumpability in a real engine. These days, a lot of people buy into the hype based on only the visual aspects they see instead of the actual technical aspects.
To add ... we know that what's recommended by the manufacture in this country is highly influenced by CAFE. Many threads over the years showing the same engines used in other parts of the world where the OM's show a whole range of recommended oil viscosity, many much higher than those recommended in the USA vehicles using that same engine.But the reality is, in a 2012 F150. Yeah, uh… use whatever the manufacturer recommended, in whatever brand you like. Etc.
I can't speak to all brands, but BMW has widened their journals on all engines specifying 3.0 HTHS or lower compared to former designs and those B series engines have IROX coatings on the bearings.Curious if the bearings in these engines specified for 0W-16 or lower viscosity are wider/larger etc. to carry the same loads over a larger area thereby enabling thinner oils to be used with no increase in wear or increasing odds of failure?
That was my suspicion simply due to the fact the load has to be dispersed. The other part I am pondering is do wider bearings equal less friction, the same, or indeed more? Theoretically and typically, more surface area equals more friction at the advantage of less load per square "whatever".I can't speak to all brands, but BMW has widened their journals on all engines specifying 3.0 HTHS or lower compared to former designs and those B series engines have IROX coatings on the bearings.
One would have to assume there is still a net benefit. I'm sure they already know via simulation before they build a single prototype. It's hard to say if the wider journals are strictly due to the thinner oils - the engines also make more power than their predecessors so I'm sure part of it is simply that.That was my suspicion simply due to the fact the load has to be dispersed. The other part I am pondering is do wider bearings equal less friction, the same, or indeed more? Theoretically and typically, more surface area equals more friction at the advantage of less load per square "whatever".
Much of this "race to lower viscosity" is chasing MPG so it does beg the question...
It would depend on how far you go back to define "predecessor" and there are many powerful engines that use or have used the same or similar bearing sizes for years, but your point is taken.One would have to assume there is still a net benefit. I'm sure they already know via simulation before they build a single prototype. It's hard to say if the wider journals are strictly due to the thinner oils - the engines also make more power than their predecessors so I'm sure part of it is simply that.
PF's lubricity test setup is clearly far more rudimentary compared to the tech that LSJr has at his disposal and I do take the results with a grain of salt. That said, it does provide a set of data points that I view as valid. The results are consistent with more advanced lubricity tests. There is a clear correlation between the amount of anti-wear additive package in oil and wear, as demonstrated by LSJr's GTX Classic vs GTX wear test I quoted in an earlier post in this thread where the difference in wear was far more dramatic. PF's arguably less accurate test reached similar conclusions. Toyota's oil had the lowest addpack of the tested oils so the result is not surprising.Even if you believe that his wear test method provides any valuable information, those results only differed by a whopping 5% I know it looks larger, more like a 2x difference between the best and worst, because of how close he zoomed in on the y-axis. A tried and true tactic of deceptive data presentation.
Results close enough that I’d be shocked if his test setup could even reliably measure differences that small. Something he could easily prove but never has. But I get it, content needs to be churned out and why bother doing even the smallest amount of experimental rigor when it’s just so much easier to amplify potentially meaningless differences by hard ranking results as 1st 2nd and 3rd place.
Would it preclude them from running higher viscosity oils?Yep, engines specifying 0W-16 and 0W-8 have special design features to run that low viscosity - journal bearings design, special materials and coating, etc.
You forgot 540 RAT data.I wish someone with a professional grade lubricity tester would thoroughly and repeatedly wear-test all oils and publish results. Until then, these tests are the best measure we have. Certainly more trustworthy than marketing claims printed on the oil bottles.
You truly have no idea what you are talking about. You are fooled just like the rest of their audience.PF's lubricity test setup is clearly far more rudimentary compared to the tech that LSJr has at his disposal and I do take the results with a grain of salt. That said, it does provide a set of data points that I view as valid. The results are consistent with more advanced lubricity tests. There is a clear correlation between the amount of anti-wear additive package in oil and wear, as demonstrated by LSJr's GTX Classic vs GTX wear test I quoted in an earlier post in this thread where the difference in wear was far more dramatic. PF's arguably less accurate test reached similar conclusions. Toyota's oil had the lowest addpack of the tested oils so the result is not surprising.
Also, I think you underestimate the wear scar size difference. Wear happens in 3 dimensions so even a tiny difference on one axis makes a big (potentially cubed) difference in the volume of metal lost through wear. A 10% difference on one axis likely means a 33% increase in wear (1.1^3).
The issue with the lubricity test is it's meant for gear oil testing....not motor oil testing. As much as you may want to believe this is telling you how well these oils perform in your engine...it doesn't. I enjoy PFs videos but this isn't a valid way to compare oils in the context of your engine. It is however a dataset as you point out with reasonable variable control etc. just not one that can be used to help with what is the higher performing motor oil.PF's lubricity test setup is clearly far more rudimentary compared to the tech that LSJr has at his disposal and I do take the results with a grain of salt. That said, it does provide a set of data points that I view as valid. The results are consistent with more advanced lubricity tests. There is a clear correlation between the amount of anti-wear additive package in oil and wear, as demonstrated by LSJr's GTX Classic vs GTX wear test I quoted in an earlier post in this thread where the difference in wear was far more dramatic. PF's arguably less accurate test reached similar conclusions. Toyota's oil had the lowest addpack of the tested oils so the result is not surprising.
That PF dude will never be recruited by the SwRI …The issue with the lubricity test is it's meant for gear oil testing....not motor oil testing. As much as you may want to believe this is telling you how well these oils perform in your engine...it doesn't. I enjoy PFs videos but this isn't a valid way to compare oils in the context of your engine. It is however a dataset as you point out with reasonable variable control etc. just not one that can be used to help with what is the higher performing motor oil.
I like them both because they make BITOGers sit in corner and cryThat PF dude will never be recruited by the SwRI …
He should stick with: glue boards with A, B, C, … add weight to failure … Rat just needs to go away like all rats …
I never thought of that and probably won’t againI like them both because they make BITOGers sit in corner and cry![]()
1st prize for the most pathetic post here. No arguments, only personal insults. Instant ignore.You truly have no idea what you are talking about. You are fooled just like the rest of their audience.
Out of every falsehood you have posted the worst one is your belief that they are presenting a valid data set.
Well let's unpack it then.1st prize for the most pathetic post here. No arguments, only personal insults. Instant ignore.
I never thought of that and probably won’t again![]()
