4WD
$50 site donor 2024
Can’t believe you cut off the Velcro tabs on his shoes
![Person shrugging :person_shrugging: 🤷](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f937.png)
My primary concern is camshaft lubrication. PF's lubricity test is a close as it gets to simulating cam lobe on slipper pad action. I don't pay any attention to the cold oil race, etc. These photos of an intake camshaft and rocker arm from one of my cars. The result of using 5W-30 "energy conserving", fully synthetic API SN oil with low levels of ZDDP. No more. Switched to better oils since I replaced the camshaft and rocker arms 2 years ago. Using only the highest AW additive oils I can find. No sign of wear, yet, on the replacement parts.The issue with the lubricity test is it's meant for gear oil testing....not motor oil testing. As much as you may want to believe this is telling you how well these oils perform in your engine...it doesn't. I enjoy PFs videos but this isn't a valid way to compare oils in the context of your engine. It is however a dataset as you point out with reasonable variable control etc. just not one that can be used to help with what is the higher performing motor oil.
From now on all you will hear is Kermit and Cookie Monster when you watch their vids - you’re welcome.I like them both because they make BITOGers sit in corner and cry![]()
Who is Scotty?From now on all you will hear is Kermit and Cookie Monster when you watch their vids - you’re welcome.
KilmerWho is Scotty?
View attachment 212099View attachment 212100
Yeah this is what I was trying to get at. Even if for whatever reason you like his test setup and think it’s going to give you a meaningful measurement he doesn’t do the most basic of steps in experimental science, make multiple measurements to quantify the uncertainty.The actual ASTM test for gear oils has huge error bars for the results, mostly due to operator variability during the test. Large variability equates to also needing a somewhat larger sample size but again, these county fair hawkers generally perform the test once. But that's only another fatal flaw.
Getting back to your assertion that it is valid data, this is indeed the worst part of those tests. No results are presented properly showing the uncertainty in the results. This is about the large error bars. If you take the time to take their worthless results and use standard uncertainty then the real result is that all the oils in the test yield indistinguishable results. In other words they all test the same.
No, that would be Sequence IVA and IVB, which are tests specifically developed to measure valvetrain wear.My primary concern is camshaft lubrication. PF's lubricity test is a close as it gets to simulating cam lobe on slipper pad action.
Oils developed to produce less wear in more demanding applications (like Full-SAPS Euro oils for example, which have higher levels of phosphorous) should yield less wear in applications that benefit from this.I don't pay any attention to the cold oil race, etc. These photos of an intake camshaft and rocker arm from one of my cars. The result of using 5W-30 "energy conserving", fully synthetic API SN oil with low levels of ZDDP. No more. Switched to better oils since I replaced the camshaft and rocker arms 2 years ago. Using only the highest AW additive oils I can find. No sign of wear, yet, on the replacement parts.
True that, used the wrong words there.No engine requires it.
So does wavy filter pleats.I like them both because they make BITOGers sit in corner and cry![]()
BUY OLD TOYOTASKilmer
Just went and spent some time at the Rat site...it's amazing...."Bozotheoilguy".No, that would be Sequence IVA and IVB, which are tests specifically developed to measure valvetrain wear.
This does not mean that half-baked backyard bench tests are any sort of illustrations of this in practice. The "top rated" oil on the RAT blog test was an "Energy Conserving" 5W-30 (Quaker State) while Valvoline VR1 racing 20W-50 "ranks" 62nd.
Scotty is alway good for a laugh. I like him. He doesn’t take himself too seriouslyBUY OLD TOYOTAS
I went through a phase where I watched his stuff, over it now but yes, entertaing and I'm sure he steams many of the super-serious types that frequent this place.Scotty is alway good for a laugh. I like him. He doesn’t take himself too seriously
I’m gonna double click from now on just for you.Scotty is banking on you patronizing his CLICK BAIT. Nothing more. Be smart. Don't take the bait.
Remind me which shampoo was head and shoulders above the rest?No, that would be Sequence IVA and IVB, which are tests specifically developed to measure valvetrain wear.
He is using his daughters '23 Corolla as test bed. Also mentioned how 10,000 mile oil changes are not a good idea and that he changed the oil twice already himself before taking it in to the dealer at 10,000 miles to see what oil they will use.
