The plot thickens. This doesn’t sound like the typical thing a thief would do.
By my count, I see 8 cut wires (orange, white) (yellow, black, gray, pink) (red, green) at 3 different locations of the wire bundle. Only the pink and gray wires show any signs of frayed plastic insulation while the others are cleanly sliced. These clues lead me to believe they were intentionally cut with a knife (i.e., not wire cutters or chewed by rodents). It does not seem reasonable that a meth/crack head would take time or have the knowledge to disable the MB in this manner. If I was a betting person, I'd say that someone sabotaged this vehicle to ensure it would be a total loss claim.Did some looking, and found about a half dozen cut wires, not to far from the Rear SAM. I have no idea why this is, from sabotage to neglect from a inspector- very much welcome any thoughts/ comments on how these wires are cut.
So-is it possible the owner of the MB SUV saw the vehicle after it was recovered? Saw the drug stuff in it and decided he didn't want it back and cut the wires. That actually sounds plausible.By my count, I see 8 cut wires (orange, white) (yellow, black, gray, pink) (red, green) at 3 different locations of the wire bundle. Only the pink and gray wires show any signs of frayed plastic insulation while the others are cleanly sliced. These clues lead me to believe they were intentionally cut with a knife (i.e., not wire cutters or chewed by rodents). It does not seem reasonable that a meth/crack head would take time or have the knowledge to disable the MB in this manner. If I was a betting person, I'd say that someone sabotaged this vehicle to ensure it would be a total loss claim.
My wild speculation. The vehicle was hit in the right rear quarter panel. When the repairs were done the wires were not properly protected and put safely back in place. This is the reason the SUV was traded in, yet was greatly maintained. Nobody could figure out the weird issues associated with unfirm electric connections.
The latest owner could not get the price blem fixed, and arranged to have the vehicle stolen. One can't steal this model without the keys. The tools were left in place to make the theft look proper. The crack pipes were staged.
I am now tracking down which I think most likely are a shorted wire to ground.
View attachment 158937View attachment 158938View attachment 158939
I have triple a and have the monster package, that will tow a rv many miles. But I didn't think it was a match to call them to solve this issue .Do you have AAA and will they move it for you? Someone like you needs to have a friend in the towing business that will move things around for you without trying to rob you blind in the process.
...I really would like to get this SUV to power up so I can get it into neutral and off the trailer.
May be the Frontier can be done the same way.I wondered about this scenario. The joys of gear select by wire with no neutral bypass.
My 2022 Nissan Frontier uses the Mercedes Benz 9G tronic that jatco is licensed to build. There's no magical button, lever or cord to get these in neutral either.
That would be a good thing.Are the transmission flushes a red flag ?
That battery location is a pain in the butt. Plus the fact that they take a very heavy battery. I had that model with the diesel engine. It was really comfortable and solid. The only big weakness with those MLs is weak steering racks. Word was they used a car steering rack in that heavier vehicle. Rebuilt ones are better than originals. If you can get it running, you will have a very good vehicle.Located at least one issue. The 100 AMP fuse to the rear SAM was blown. The rear SAM controls almost everything in this car outside of the engine bay.
It was quite a job to get to the fuse. The battery has to be pulled which is located under the passenger front seat. To get at the battery, the passenger front seat must be all the way forward, which it was not. And nothing working, so I tried to pull the front seat, but did not have success- this is a real big design flaw, as one can't get to the battery and pre-fuse compartment if the front passenger seat is not functioning.
I checked the incoming voltage at the rear SAM, and it was zero. I placed 12v on the rear SAM, and was able to move the seat. forward. Nothing else worked, but what I needed to work did. I moved the seat forward and pulled the battery. This is the hardest battery I can recall trying to remove. I saw no signs of anyone trying to get under the passenger seat prior to me.
Measured resistance across the power distribution fuses, and the rear SAM fuse was blown which is what Mercedes call a "fuse strip". Hopefully Mercedes has these fuses in stock.
Of note, the car is super clean. No rigging of any nature, everything OEM everywhere. The CARXFAX showed this car had extensive and continual preventative maintenance at the MB dealership. One example, two transmission fluid exchanges were performed under 100k miles.
Either this car has something really wrong, and it is a insurance fraud case, or someone stole a really nice car. Hope to have better understanding tomorrow after the fuse is replaced.
I can't get a trailer to where I live, so I have to work on the car about seven miles away from home until I can drive it home. Very inefficient not having tools close by.
View attachment 158699View attachment 158700View attachment 158701View attachment 158702View attachment 158703
Yes and no. Many times a service advisor will recommended a flush when a customer comes with a transmission concern. Having two flushes close together is a red flag.That would be a good thing.
These vehicles have a lot of fiber optic cable in them. If the battery has a small hiccup, the car will do all kinds of goofy things and throw codes totally unrelated. I've had to learn this the hard way. That could be a reason the owner took it in. Batteries will demonstrate proper voltage and amps and still cause all these things. New AGM battery solves everything. I had a 2000 CLK that had all kinds of crazy things and codes going on. Sometimes the dealer computers won't pick things up if they are intermittent. It takes a real experienced MB mechanic to find these things. Turned out my CLK needed a new headlight switch. Behind that round headlight switch is a fusebox full of fuses. It seems MB runs a whole lot of electronics thru that switch. The ABS BAS system runs through that switch. Crazy. This is why most people trade them in. All most dealer techs know is to hook it up to the computer and do what it says.Was the battery inspection THE LAST time that it was at the Stealership? And is that a normal inspection? It's starting to sound like someone had a car with a difficult to solve electrical problem but then the car was suddenly "stolen".
IMO most electrical problems are not difficult for anyone that understands electricity to solve. Blown fuses are usually caused by an improperly routed main wire that shorts out against a metal panel or a hot exhaust pipe. A 100+ Amp short should not be hard to find!
It's supposed to be done every 37k miles. It's not flushed, just a pan drop and filter change. Some have converter drains and some don't.Yes and no.Many times a service advisor will recommended a flush when a customer comes with a transmission concern. Having two flushes close together is a red flag.
