He says here.I'm sorry, I missed what car is that?
Any photos from before through the fill cap?with the infamous red gunk from BMW oil
This is absolutely remarkable!Regarding cleaning power of RL HPMO
This was a preowned 2000 BMW I acquired, with the infamous red gunk from BMW oil.
Ran RL 5w40 for a couple years and had to replace VC gasket. When my mechanic did the service, he was astonished and took pics:…
Yeah this is amazing since Red Line says their oils don't clean but anecdotal reports show otherwise. @Mainia had a very impressive experience with Red Line Euro resolving his fuel dilution issues in one OCI too IIRC.This is absolutely remarkable!
Do you happen to remember the milage?
Not even with bypass filtration would I do it on a gaser! Maybe with twice the sump capacity or more, bypass filtration on vechile, bypass cart and sweetening the sump contents over time! LOL I doubt todays engines could benifit from it due all of the extreme compromises in internal engine design!So, go to 30K intervals and you will be ahead with HPL.
And yet, it’s been done, with success, and great UOAs, without all that.Not even with bypass filtration would I do it on a gaser! Maybe with twice the sump capacity or more, bypass filtration on vechile, bypass cart and sweetening the sump contents over time! LOL I doubt todays engines could benifit from it due all of the extreme compromises in internal engine design!
Too easy to get a $25 5 quart jug from Walmart and change oil every 5000 to 10,000 miles depending on the engines design! Rinse and repeat just like cheap Creme Rinse! LOL
You know what, this is a very strong data point, yet I would not feel comfortable using the same oil even for 10K miles.And yet, it’s been done, with success, and great UOAs, without all that.
Just running HPL.
Nothing more.
After some discussions with @dnewton3 I have decided that I will continue to run this oil. The ultimate question is, how far can this oil be run before it reaches an ultimate condemnation and what will that condemnation point be? Some possible condemnation points could be:
I will take mileage interval pictures of the valve train to check for deposits and send in another oil sample to be tested.
- Varnish deposits
- High viscosity from oxidative thickening
- Low TBN
- Rapidly increasing wear metals
[edit Jan 7, 2024] - The oil has been changed see this...
- wwillson
- Forum: Passenger Car Motor Oil (PCMO) - Gasoline Vehicles
LOL indeed.
Shear. And yes they are using high quality VII that does resist shear better.I will rationalize that to myself saying because I have a Subaru, and its timing chain is long etc. even though I know very well HPL would not sheer a bit over 10K miles.
What do you mean by that?Yeah this is amazing since Red Line says their oils don't clean but anecdotal reports show otherwise.
https://www.redlineoil.com/5w30-motor-oil
- High detergency allows extended drain intervals and provides increased cleanliness
I believe not all esters/G5s have the cleaning effect, but I would definitely consider RL to be a well cleaning oil, even though not HPL levelWhat do you mean by that?
I bet all Group 4 and 5 oils clean by default.
Second half of the page, 4th bullet below the video:
The same info is written under each grade.
PAO doesn’t really clean.What do you mean by that?
I think they usually come with high solvency group 5 to better dissolve the ad pack, and I guess that is why we often think PAO cleans. It may not, but what it is bundled with does.PAO doesn’t really clean.
Esters, no?PAO doesn’t really clean.
Our High-Performance Motor Oils start with a PAO/Ester base making us a true synthetic oil. Add in our proprietary additive package with enhanced ZDDP levels and you have a combination that is engineered to protect. We offer 16 different viscosities to give you maximum coverage no matter what you drive.
Maybe not all esters clean, but all boutique oils clean very well. They don't emphasize that like Valvoline Restore and Protect does, because they are not Group III oil like the Valvoline, so the cleaning ability is remarkable in that case.I believe not all esters/G5s have the cleaning effect, but I would definitely consider RL to be a well cleaning oi...
I do not think Red Line has said their oils do not clean. I think what they say is "We purposefully design our oils not to clean!" put another way they do not design them to clean. That is not the same as saying their oils do not clean. I am sure when the original Mobil 1 0W40 came to market and ExxonMobil claimed it had the ability to clean an engine that was a happy side effect from other design criteria and marketing ran with it.Yeah this is amazing since Red Line says their oils don't clean but anecdotal reports show otherwise. @Mainia had a very impressive experience with Red Line Euro resolving his fuel dilution issues in one OCI too IIRC.
Nicely written, but I would think todays oil is superior to what we had back then. I was just reading @wwillson 's post on using the same oil for 30K miles and having steller cleaning results. It is HPL, so hardly representative of what a regular off the shelf product can do, but I don't think anyone could even dare to imagine running an oil for 30K miles and still have such good outcomeI do not think Red Line has said their oils do not clean. I think what they say is "We purposefully design our oils not to clean!" put another way they do not design them to clean. That is not the same as saying their oils do not clean. I am sure when the original Mobil 1 0W40 came to market and ExxonMobil claimed it had the ability to clean an engine that was a happy side effect from other design criteria and marketing ran with it.
All esters do not have the same polarity, solvency, temp. resistance etc.....Just like not all of them play nice with the same seal materials etc....I am probably eating my hat here but they chose esters in combination and ratios that do not lend themselves to aggressive cleaning. Likewise not all PAO's are the same in properties and characteristics. Aniline point and the length of carbon chains have a HUGE say in how these all behave. Most PAO's have almost zero polarity or solvency but some do.
In the old days group 1 GI had a lot of solvency part of that was impurities that remained after refining and part of it was solvents that where added during extraction left over. Each leap up in saturation from G1 to GII to GII+ to GIII to PAO left us with a lot of incredible improvements in the base stock and allowed us to make exactly what we wanted and often from less expensive starting materials. Natural polarity and solvency all but vanished. There is a reason Mobil 1 PAO+Mineral for additive addition was a thing. Amsoil avoided this by using Diesters from Hatco. In my life time I do not think there has been an oil with the polarity and solvency and cleaning power of original Amsoil. Remember Mobil 1 Tri Syn that was when EM started playing around with AN's and we had PAO+Ester+AN's and I thought those where some of the best if not the best Mobil 1 formulations we ever got from Mobil! The formula changed often at first and the additive packages changed often. Not everyone was a fan boy of Tri-Syn like me though. AN has largely replaced ester usage in most motor oils. For the most part ester's seldom make up more than 2% of an OTC fully formulated ICE motor oil not counting boutique oils today.
In fact it was once common practice to use some sort of engine flush before switching to synthetic. I think that Amsoil was the main force behind this. It made sense with their original Diester formula. Today not as much. Most synthetics just lack the solvency and polarity to clean aggressively like that!
I think plenty of brands including boutique oil brand that have proven themselves to put out at the very least a product that will do no harm! Amsoil long ago proved that and I think Redline has too. Obviously I trust EM, SOUPUS and the rest to in large part do the same. So TRUST is part of the game as well.
It is funny back when ester content was high in a lot of different formulations no one focused very hard on the oils ability to keep an engine clean. Today we want what we once had but can not have. Would love to have old Amsoil formula back at current prices even. I am sure it would be 2X or 3X as much as today’s current price though. Any formulation saving's never result in lower price to consumer at best price remains static usually though the price goes up even when cost goes down! Castrol Syntec never lowered price when they switched from PAO to GIII!
What we all want to know is what is the chemical that is not an ester that is responsible for cleaning in the Valvoline Restore and Protect. I am taking a swag and thinking it is likely an amine. I am likely wrong but if I had to rule out esters and wanted to clean gently in an engine I would likely use that as a starting point.
I did forensic engine tear down well not just engines as part of quality control for a major automotive firm. I would have to see the engine especially the pistons, valve train and timing chains after multiple 30,000 mile oil change interval weight each part, measure each part and sample the deposits myself to put any stock in 30,000 mile oil change intervals!And yet, it’s been done, with success, and great UOAs, without all that.
Just running HPL.
Nothing more.
- Varnish deposits
- Low TBN
- wwillson
LOL indeed.
Yes! In almost every way they are better today. The problem is that engine design changed and the lubricants now are not even close to being up to scratch for the terrible compromises that have been made to engines from the consumer stand point.Nicely written, but I would think todays oil is superior to what we had back then. I was just reading @wwillson 's post on using the same oil for 30K miles and having steller cleaning results. It is HPL, so hardly representative of what a regular off the shelf product can do, but I don't think anyone could even dare to imagine running an oil for 30K miles and still have such good outcome
So what compound of amine or a amide would result in cleaning?...Last I checked they were not making anything for Lycoming or Coninental engines!
