Admins, please lock this thread. This became an area for personal vendetta and biased policing comments. I will kindly report this message to make sure admins see it
I'm not aware of what happened above, but hold on a little because I'm waiting on a response by Red Line oils on your concern of what 40 grade oil will be best for your application.Admins, please lock this thread. This became an area for personal vendetta and biased policing comments. I will kindly report this message to make sure admins see it
Thank you for reaching out to us. Regrettably we do not have an oil that meets the specification fo Ferrari for this oil.
No it does not. Atleast not from the aspects that the 0w-40 was praised for which was PAO and ester use. SP 0w-40 has no ester anymore or ANs but has more PAO than before. 5w-40 had neither for SN or SPSidebar - So, what I am picking up from this thread is that Mobil 1 Euro 0w40 formula is a solid choice? IIRC, I have only ever seen 5w40 in stock at my local Wally.. Does 5w40 get the same wrap as the 0w40?
Carry on Gents![]()
What that means - Group III and PAO (the first two)?This was on the website now...
GTL/PAOWhat that means - Group III and PAO (the first two)?
Think I have a jug from that era - But IIRC, lots of calcium …No it does not. Atleast not from the aspects that the 0w-40 was praised for which was PAO and ester use. SP 0w-40 has no ester anymore or ANs but has more PAO than before. 5w-40 had neither for SN or SP
Ive got 2 left and idk 5-6 quarts in a 12 quart bag in a box to. 3200-3600 calcium depending on labThink I have a jug from that era - But IIRC, lots of calcium …
Thanks a lot!GTL/PAO
Good for 10k in some twisty motors !Thanks a lot!
Is that good or not so good (since there is no more esters)?
I disagree - there isn’t a personal vendetta here - what is here is your stated goal of understanding the difference -Admins, please lock this thread. This became an area for personal vendetta and biased policing comments. I will kindly report this message to make sure admins see it
The best OTS oil they'd tested. Applications? Basically anything. It's been the "universal" oil of this forum for many years, because it will work well in pretty much any gasoline application.What and for what application they recommended it?
Because he asked about early 90s Ferrari 348, 3.4L, V8, dry sump.The best OTS oil they'd tested. Applications? Basically anything. It's been the "universal" oil of this forum for many years, because it will work well in pretty much any gasoline application.
AMSOIL is quite conservative with their recommendations, so that doesn't surprise me.Because he asked about early 90s Ferrari 348, 3.4L, V8, dry sump.
Amsoil said in a email that they don't have oil for that engine, which sounds a bit weird to me.
Thanks for the info!AMSOIL is quite conservative with their recommendations, so that doesn't surprise me.
This car called for Agip Sint 2000 10W-40:
Which is a basic A3/B4 lube, nothing exotic:
Mobil 1 0W-40 would be more than up to the task for this application.
My question was this:I disagree - there isn’t a personal vendetta here - what is here is your stated goal of understanding the difference -
Without telling us what you’re trying to achieve.
And you find fault with most of the suggestions. Well, it would help if you told us the whole story from the beginning, instead of dropping a few facts, then arguing, dropping a few more, and repeating the process.
You’ve got a classic car. Ferrari 348.
And you want what, exactly from your oil selection?
See, that’s the part missing. You quote an HTHS number - without saying why. You have not told us what was specified for this engine by the OEM. You have not told us the operating conditions (street, track, parades) or the oil temperature in those conditions.
So, how can we possibly help you out? What difference between the oil do you seek?
The only thing we have to go on is your choice of a certain HTHS - and even that isn’t clear. You want help, but you’re not willing to provide details, and you’re getting into arguments along the way.
If anything, given the paucity of clear goals and information - it looks like you’re trolling by moving the goalposts every time someone has a suggestion.
