So my volvo T5 turbo will soon be running 16 PSI instead of the factory 9 psi. The maximium this turbo will push is 18 psi or so until it goes beyond the limits of its efficiency. So there will be alot of heat generated at the turbo bearings, especially with a rear mounted turbo.
Ive read a story recently of someone with the same sort of boost level developing noisy turbo bearings. This could be caused by hot shut downs, faulty bearings, etc. im not sure but it's made me reconsider my choice of Mobil 1 0W-40. My manual calls for a 0W-40 oil, and that's it. Earlier models with the same engine asked for a 5w30. Why the changed to the 0W-40 i don't know, but i guess there is a good reason.
I would like to stay with the 0W-40 weight RL, for warranty reasons. Even though i know RL isn't certified, if i do need to make a claim i can at least plead the correct grade of oil was used. Regarding the engine mods, i can get around that.
Question - looking at the Redline web site and doing a search here, it looks like the 5W-40 is a better oil for the job. Can the 0W-40 still put up a good fight for what i have intended out of this motor? Which one to go for? 5W-40 and worry about the warranty claim if it ever happens (unlikely)?. Specs for both below, and i would still like to follow the manufacturers 15,000 km OCI if possible. Hope you can help!
Viscosity Grade SAE 0W40
Vis @ 100°C, cSt 15.1
Vis @ 40°C, cSt 81
Viscosity Index 197
CCS Viscosity, Poise, @*C 57@-35
Pour Point, °C -60
Pour Point, °F -76
Flash Point, °C 218
Flash Point, °F 424
NOACK Evaporation Loss,1hr @ 482°F (250°C), % 9
HTHS Vis, cP @150°C, ASTM D4741 4
Viscosity Grade SAE 5W40
Vis @ 40°C, cSt 94
Viscosity Index 170
CCS Viscosity, Poise, @*C 55@-30
Pour Point, °C -45
Pour Point, °F -49
Flash Point, °C 250
Flash Point, °F 480
NOACK Evaporation Loss,1hr @ 482°F (250°C), % 6
HTHS Vis, cP @150°C, ASTM D4741 4.6
Vis @ 40°C, cSt 81
Viscosity Index 197
Pour Point, °C -60
Pour Point, °F -76
Flash Point, °C 218
Flash Point, °F 424
Vis @ 40°C, cSt 94
Viscosity Index 170
Pour Point, °C -45
Pour Point, °F -49
Flash Point, °C 250
Flash Point, °F 480
