Originally Posted By: BaReinhard
Just so I can clear up the theory portion of your post am I reading this correctly?
As the engine partially combusts fuel, liquid nitrated and oxygenated monomers will form in the oil. With the monomers present in the oil and exposed to heat they will turn to varnish then eventually sludge if left untreated. In addition, if the monomers are exposed to carbon/water/solids they will turn to sludge without needing to turn to varnish.
Basically. You have combustion byproducts that are picked up by the oil as well as the oil breaking down itself due to exposure to areas like the ring lands, where heat is intense. There is only so much room in the oil for these contaminants before they start to fall out of suspension and plate surfaces where oil flow is low, such as the lifter valley, rockers, tops of the heads....etc. Once you hit this tipping point, cleaning this back up, after the deposits have formed, is difficult, as per what Shannow noted, this stuff is polar and it wants to stick. On top of that, it wants to stick to itself, so you do this a number of times and you get built-up layers of this garbage, which in turn changes its colour. The more that has plated, the darker it gets. When it gets REALLY thick it will look black, but it hits a deep red hue first, which is what your equipment exhibits. Also, keep in mind carbon will tint it. If you have an engine with a lot of blowby, it can tint the varnish darker than an engine that doesn't, even at the same thickness. So your earlier observations about black deposits, if that was an older 80's mill with poor crankcase ventilation control and a fair bit of blowby, it is quite possible that the varnish levels you are seeing here are just as bad, they simply lack the carbon tinting to make them appear black. Food for thought.
Regarding sludge, the way I read the diagram is that varnish + carbon/moisture/solids creates sludge. You need that resin to bring it all together to create the sludge, but you also need the other three components. I think this is most clearly articulated in the bottom part of the diagram, whereas the upper triangle part might be a bit more confusing.
