cool, I used to have a 2005 Taurus, very comfortable car ! And I could lean in , change the oil filter- used a MITYVAC to change oil and trans fluid. Used Redline ATF- Transmission was still smooth when I sold it @120,00 miles2004 Ford Taurus
CAM2 5W-20 GF-6A oil
Almost 7000 miles on oil.
Pic taken while oil warm, about a half hour after shutdown. Level doesn't seem to change cold to hot on this car, which is actually a bit strange.
View attachment 166473View attachment 166474
Added paper towel blot test
View attachment 166475View attachment 166476View attachment 166477
yep, PF screwed up the LM Ceratec test. It takes time for it to set in and bond to metal. If these tests aren't going to true and accurate then he should just stop. I would soon watch Piotr Tester on YouTube. His musicNo. Totally different.
PROJECT FARM : The winner is ?
BITOG Disclaimer: The Project Farm channel states that its videos are for entertainment purposes only. Project Farm does not perform ASTM tests, nor apply industry acknowledged methods and criteria, and therefore BITOG cannot endorse the results of tests of any lubricant or filter or similar...bobistheoilguy.com
No, color is not a valid indicator. Aminic antioxidants change color quickly, but are still protecting the oil. A smart oil guy told me that, but I don’t know the specifics of function.Do you consider oil color as an indicator of degradation/oxidation?
2003 Jaguar S-Type 3.0 V6
Oil: Quantum full synthetic 5W-30
Miles on oil: 5,000
2003 Pontiac Vibe GT (2ZZ-GE Yamaha engine)
Oil: Shell Rotella T6 5W-40 and PP 5W-30 (3:1 ratio)
Miles on oil: 300
My Vulcan is signature is about to roll 200,000 miles here in the next couple weeks. Running better then ever. Really likes the 5W30 over the 5W20 on the oil cap.2004 Ford Taurus Vulcan 3.0L V6
11,129 miles OCI
Thinking of doing a filter cut-open or a UOA (down the road on the UOA..)
View attachment 169242View attachment 169243View attachment 169244View attachment 169245View attachment 169246
Now at 4,000 miles (Mobil1 5W30)3,000 miles on Mobil1 5W30
125,000 miles on the car (2016 Toyota Avalon). Just bumped up to the 5W30 from 0W20. Have done a few 10,000 mile intervals using Mobil1 0W20 EP. Now using regular Mobil1.
2.0L Tiburon with 229,007miles. 1007mi into the oil change.
Mobil1 10w40. Car typically burns a quart every thousand miles. Although the first quart is usually consumed within 1200-1500 (then is topped off) then the subsequent top offs are burned off within 800-1,000 mi. So idk. I just go with a thousand to keep it simple.
So I really don't want to jynx it. But the car now has 232,213mi.^i went ahead and kept pushing the car til the 1250mi mark or so until I topped off a quart. Could've gone to 1400 before it hit the bottom line but I saw no reason to wait.
So update to this.So I really don't want to jynx it. But the car now has 232,213mi.
Meaning it has 1,213mi since the last oil change. In which I did a treatment of BerrymanB12. And it appears the oil is still above halfway on the dipstick... last time the oil was getting too close to the "L" for comfort so I topped it off at 1250mi. Improvements? (still using Mobil1 10w40 HM)
