In late 2021 I discovered a wiped intake camshaft on one of my 2ZZ-GE equipped Pontiac Vibe GTs. https://bobistheoilguy.com/forums/t...intake-cam-wear-bad-oil-or-bad-filter.348741/ . I replaced the intake camshaft and 4 rocker arms and adjusted valve lash. After extensive research, I concluded that the root cause was inadequate ZDDP content in API 5W-30 oils used (SM, SN, SP). The car calls for 5w-30 API SL.
FFWD to now, I'm doing the same job on my other Vibe GT. This intake camshaft is again wiped although it's not quite as bad as it was on car #1. This car wasn't driven as hard. As was the case with the 1st car, the exhaust camshaft is perfectly fine and all cam journals and cam caps are in excellent shape. The difference this time around is that on the 2nd car, all intake valve clearances were prefectly in spec, 0.13mm on all 4 cylinders (spec is 0.08-0.18 mm). This is a confirmation that valve clearances are not the issue. API 5W30 oil was the problem all along after the arbitrary 800 PPM ZDDP limit was imposed with API SM.
I switched to high ZDDP 0W40 oils in both cars back in 2021. In these high-revving engines, there's no substitute for proper levels of ZDDP (over 1000 PPM). Higher viscosity also helps keep the cam lobes lubricated at RPMs over 8,000. For track use, I'd go up to xW50 or xW60 as some owners already do.
