Is the "wire backing" still metal? Is it magnetic? You mentioned 13k in the beginning & then said 10k at the end? It appears as though you've changed the oil & reused this filter? Thanks!
Yes! I've got kind of the "running oil change" going on. Lost about a quart when the Orange Can - hold on. This one:
- "wouldn't fit." I'm really not sure why, either.. I think I had one on this car before. But exhaust manifolds are HOT! OUCH..
Anyways. So it's MOST of the oil oil.. some HPL and some Castrol 5W-20 now. Should run it out another 15k, honestly.
Now, about magnets..
Here is a magnet..
While there is SOME magnetic attraction ON THE CAN, the wire backing appears to be mesh.
I'm just a guy in a garage in a house.
So we have about 1/2 the oil changed in 13k miles (NO oil consumption. NONE. Good engine, this one) in the still Running Oil Change consisting of CAM2 5W-20, Castrol Edge Black jug 5W-20, and about 1/2 quart of HPL. New filter. Should run out to about 160k, honestly.. although
@LDB called it, the old oil drained looked dark. Not black. But dark. See 2nd pic.
Car runs better with new filter and fresh oil. This should be noted.
Anyone wants that Fram, DM me. I might just use their Titanium from now on.
@fantastic okay apologies on being confusing. Here is what occured: Around 8, decided to change filter because it's about to race up more miles . Bought Orange Can Fram. Got back home. For some unknown reason, it didn't want to thread on. Lost some oil when verifying that. Got frustrated. Decided to put the filter pictured back on, go to store, get a NEW FE3600. Got back home, changed filter in about 30 seconds.. I can do it like a pro with the slightly shorter FE3600 and it goes on like it never left. So there is a NEW FE3600 on there and this one is obviously cut open and shown.. "about half the oil has been changed" this due to disposal concerns, you see my container. So there is some re-use of oil, changing it all requires ramps and two containers and a wrench because no Fumoto valve or anything and well then there is the whole 10k OCI debate, of which I believe it can probably go to about 15k. So sorry for the confusion. And if you use all the oil in the stash, you won't have it anymore lol...
Here's the oil that made up the difference. They were the lucky winners in the Stash. Oil-dri on the floor and all is well. I need to order more HPL. I'm not gonna use that Orange Fram so. I'll update tomorrow in the other thread about that.
DATE CODE:
23018AF 09:09
PRODUCT OF USA
