Originally Posted By: Craig in Canada
Like clogged arteries, eventually sludge will do damage, how much and when is the question. Unlike blood work to detect cholesterol in an attempt to avoid the damage in people, a UOA is not going to detect damaging sludge in an engine. Fuel dilution and coolant perhaps, then will still have issues with the accuracy of the reports. JMO
But sludge only forms when the oil has deteriorated past a certain point. Varnish can be a function of high heat and a number of other things, but sludge is not. A UOA should easily be able to detect conditions conducive to sludge formation (high moisture, high fuel, low TBN, high TAN etc...)
I'd probably have to dig really deep to (hopefully) find it, but (even though it wasn't the focus of the white paper) there was a very well written description of different factors that could create sludge (the person writing it, because of his background, was someone I accepted as an expert).
Some of the factors were things I wouldn't have thought of; for instance, he stated that a poorly ventilated engine area can, if conditions are right, result in oil sheering, and hydrocarbon cracking that can form sludge. The description made me think of a car stuck in traffic in summer heat, where no air is being pushed into the engine bay beyond what the electric fans can pull in when they spool up.
I wish I copy & pasted and saved the write up.
Edit: I think there is an important difference between varnish and sludge; varnish will occur naturally over time, and is not only normal, but not even harmful. Given that it may provide an additional friction barrier between metal, it *may* even be beneficial.
Varnish is only bad (imho) when its allowed to go beyond varnish, and sludge develops. Sludge is never a good thing. Varnish I would not only not be concerned with, but I would be more concerned about taking drastic measures just to remove it (solvents, abrasive detergents, etc).
-Spyder
-Spyder
