Have you considered the extra load on the alternator to run that light??I actually like that green eco light. Green is the color of rainforests and less money spent on gasoline.
I'm able to get 27.5 MPG on the highway with van fully loaded with 8 people + heavy luggage.Have you considered the extra load on the alternator to run that light??![]()
Sensible advice Pablo. Thanks.A good synthetic 0/5/10W-30 changed every six months.
That's what I would be doing.A good synthetic 0/5/10W-30 changed every six months.
I don't see a topline true synthetic oil sludging at 5K and or six months even in that V6Sensible advice Pablo. Thanks.
That advice would apply to 95% of all vehicles. It's the remaining 5% of engines that have design defects that allow certain parts of the engine to have extreme heat that could be an exception.
I could change every 4k miles / 6 months as I've been doing, but with 4 vehicles and the 4 vehicles going a combined annual miles of 52k miles, it is a lot of oil changes and cost, so that was my motivation to extend to 5k/6 months. So the purpose of this thread was with this particular Honda J35a7 V-6 engine with VCM enabled, if 5k OCI was safe without adding any new sludge/varnish over the next 100,000 miles on each vehicle.
Ceretac is a friction reducer. Nothing more nothing less.Your TC will fault when you are 1 week and 5 miles past the warranty.
I also used LG Biotech from virtually the first oil change (got the car at 6k from a dealer loaner). I used LG Biotech, Ceratec and Castrol Edge 5w30 (speced for Volvo) and none of this helped. Volvo still developed the dreaded stuck ring issue and oil burning at 75k/miles. Which made me wonder if LG Biotech and Ceratec claims are just Bull+$;"83 claims used to separate the naive drivers that love their cars from their money.
Honda Odyssey EX-L's: 8 passenger, Navigation/DVD screens, with VCM enabled on all 4 vans:
2006: 122k
2006: 172k
2007: 114k
2007: 132k.
Thanks Scotty for that insight.My opinion based on my experiences and expertise. I own 3 Hondas with the J35:
2006 Pilot AWD, does not have VCM, 266k miles, no issues, daily driver now for a second teen. No oil related issues, never fouled plugs.
2019 Pilot, 87k miles, VCM disabled at 36k miles, no issues at all.
2011 Odyssey, does have VCM (probably version 2.0 versus your 1.0), 220k miles, my daily driver after being handed down from my wife. I disabled VCM about 160k miles when I started noticing oil consumption and then started seeing some misfire counts when I checked with code scanner, I dont think they were bad enough yet to set the CEL. I disabled VCM and replaced the plugs in the rear bank. Oil consumption went away, really has no oil consumption even now. Replaced plugs again recently at 210k miles, looked good, but clearly more oil on the back bank plugs, so there was some ring wear on the VCM cylinders. Engine runs fine, some issues with 6 speed AT but I can live with it since its been paid for like 6 years.
So, opinions about oil based on those experiences:
They have all gotten Mobil 1 in the last 7 years since I started doing all of my own maintenance work. I have also used PP or Valvoline but rarely. Before that, they all got Kendall Full Synthetic from the shop I used.
I posted a oil test result recently on here and also some borescope pics. Pretty clean inside, no oil related issues at all.
I am going to stick with Mobil 1 Extended Performance High Mileage or Pennzoil Platinum High Mileage or Valvoline Extended Protection High Mileage and not worry at all.
I would recommend disabling VCM based on my experiences with it and the thousands of other issues people had with early VCM.
You said you wanted to keep those Odys for longer, take care of the clear coat and rubber trim, that is the issues with mine.
Hope this helps.
For all three J35s, I have followed the Maintenance Minder oil change intervals for their entire lives. Maybe that is a helpful data point on OCIs. I posted some pictures from inside the valve cover of the 11 Ody recently. Here is a link:So, my concern for the 2005-2007 VCM version 1 is the extreme heat on the front cylinder heads which fries the oil.
I would see a $500 cost savings over 5 years if I could go from 4k/6 month OCI to 5k/6 month OCI safely without any new sludge or varnish, so the reason I created this thread was for me to hopefully get an answer that 5k/6 month OCI are safe with no new sludge/varnish deposits expected in these 2005-2007 VCM engines.
Thanks Scotty for that additional info.For all three J35s, I have followed the Maintenance Minder oil change intervals for their entire lives. Maybe that is a helpful data point on OCIs. I posted some pictures from inside the valve cover of the 11 Ody recently. Here is a link:
Post in thread '2011 Honda Odyssey, 210k miles, 9800 mile UOA, Mobil 1 High Mileage 0w20'
https://bobistheoilguy.com/forums/t...-mobil1-high-mileage-0w20.370403/post-6557202
I have used the fill cap designated weights which is 5w20 for 06 and 0w20 for 11 and 19Thanks Scotty for that additional info.
Were you using the recommended 20 weight oils or were you using 5w30.
I moved to 5w30 for everything as it might have less chance of forming varnish in high heat parts of the engine.
Yes, I've had that temptation. The green side of me (a combination of 2 greens: Save the green money + save the planet) both stop me from disabling the VCM. LOLJust rip off the bandage and shut off VCM. That 1-2 MPG desire is ridiculous if you're picking that over the life of the motor.
You're not saving money if you end up spending it on replacing the engine when the rings inevitably give out.Yes, I've had that temptation. The green side of me (a combination of 2 greens: Save the green money + save the planet) both stop me from disabling the VCM. LOL
Bill- I got an '08 VCMII equipped engine with 108k. I do 5k oc, service that PCV valve frequently. Runs great, super smooth, strong runner and get 30+ mpg running high speed on interstates. No oil consumption, no varnish or sludge observed, or any mechanical issues so far. Just normal maintenance. I estimate about 75% highway miles, where VCM is heavily engagedI'm able to get 27.5 MPG on the highway with van fully loaded with 8 people + heavy luggage.
I'm happy with the VCM's MPG. Since my vans will be driven a lot in the upcoming years, was just asking if it's safe to go to a 5k/6month OCI with VCM enabled and not add any new sludge / varnish. Not sure if anyone has that answer, as most people own the newer generation of Odysseys.
