Originally Posted By: Spyder7
Some of the factors were things I wouldn't have thought of; for instance, he stated that a poorly ventilated engine area can, if conditions are right, result in oil sheering, and hydrocarbon cracking that can form sludge. The description made me think of a car stuck in traffic in summer heat, where no air is being pushed into the engine bay beyond what the electric fans can pull in when they spool up.
I'm guessing, but you could have misinterpreted what you read based on what you wrote here. It's been discussed that improperly functioning crankcase ventilation (PCV/CCV system) will cause sludge buildup. A couple of paraphrases down the road and that could easily be misinterpreted by a casual reader as "engine ventilation" in the way you've described it.
The two are not the same. Hot engine compartments and oil simmering in poorly cooled, low circulation areas usually forms varnish and coking more than gooey sludge from everything I've read.
