5w30, 10w40, 15w40, 20w-50.... But what about Specifications? Should I stick with something rated API SL (or older spec) due to flat tappet, pushrod design or are newer API specs also fine?
How often is 'often'? I'm thinking about changing it every season or every 2nd season, in the spring, to get all the moisture out. That'd mean every 1200 km or every 2400 km accordingly...
And no, not shared with gearbox/clutch. Gearbox has its own oil pool but that's another question. Each gear makes it's own unique noise, you can distinguish which gear the car is in even being blindfolded (not seeing/feeling the car's speed
Absolutely no cold starts / warm weather only. Car hits the roads only when temps are 10°C / 50 F or higher.
Isn't M1 V-Twin 20w-50 a morotcycle oil? What's the difference between motorcycle and passenger car engine oil?
Regarding no difference of synthetic VS mineral - members of our local club have different view on this - they specifically recommend mineral because it's not able to hold contaminants in suspension - contaminants are getting centrifuged or settle out in the pockets or an engine thus reducing risk of getting some dirt into main or rod bearings and doing damage.
The engine itself is dirty - there's lots of black residue everywhere. Basically it's cooked oil / sludge / blow-by gasses.
Lead substitute: no, I don't use it. It's not required as there are cast-iron valve seats.
And yeah, the vehicle is a cool one. I like it. In each and every aspect it's different than most (if not all) of them on the road
Thanks!
