ACEA A3/B4 oils still relevant in 2024 for Turbo GDI 'High performance' Engines? - Hyundai ElantraN
Yeah. I've heard about the dealers. Will be really surprised if they are able to pick up the difference between 0w-30 vs 5w-30.
Anyway hoping it never gets to that.
Haha no. The dealer will not be able to determine the winter rating. It’s also allowed to slip one rating in use so good luck with that.
Even though only one grade is listed it’s still a recommendation not a requirement.
I agree that 0w30 is the future for regulators and formulators (vs) 5w-30
Studying the MSDS pdfs, I see a lot of 0w30 have good base stock content (Grp3+/PAO/Esters) compared to 5w30
Among >3.5 HTHS ACEA options, I see a lot of C3 versions but it's a shame that A3/B4 Full SAPS versions are left out.
A3/B4: Ravenol SSO, Castrol A3/B4, Motul 300v
C3: M1 ESP, Pennzoil/Quaker State Euro LX, Castrol LL, Amsoil MS Euro, LiquiMoly 4210, Motul XClean 8100+EFE, Shell Helix Ultra ECT
Even among these not a lot of oils carry API SP Engine test requirements label.
Not a lot of cheap options on Walmart either compared to 5w30 C3/A3-B4 options.
It CANNOT carry SP! There is a limit on phosphorus amount and A3 XW30 oils have higher Phosphorus content. Just bcs. it is API SL doesn’t mean it is outdated! Castrol Edge 0W30 has BMW LL01 approval which was updated last time in 2022. They are as current as it gets. Also, high ZDDP content is better in mitigating LSPI than low calcium. We discussed that numerous times here.
Right!
Good to know that Castrol got the updated to SP too. I haven't seen updated VOA for 0w30 here.
It's just that M1 FS 5w-30 carries the label 'confirms to API SP Engine test requirements'
Right!
Castrol 0W30 A3 is not SP, it is SL! API is irrelevant in Euro approvals. They are far more stringent than API.
Ah, I misread your statement that it's updated for BMW LL01.
Yeah, I see that the forum has extensively discussed LSPI topic and ZDDP's effects on it.
I think that even with high ZDDP, you need new detergent formulation to clear API SP. Not sure if Castrol does this.
Comparing just Engine test requirements:
ACEA A3/B4:
API SP:
The valvetrain wear test limits in API SP are actually tougher than ACEA A3/B4.
For a XW-30 oil to pass both API SP and ACEA A3/B4, the oil needs to pass additional LSPI/Chain elongation tests in API SP to get the label "meets API SP Engine tests requirements". (not the starburst logo)
This was already discussed at https://bobistheoilguy.com/forums/t...-sp-rc-ilsac-gf-6-and-acea-2021-specs.362023/
I am sure most ACEA A3/B4 oils would easily ace the LSPI/Chain elongation tests if they have the re-formulated detergent pack. (Low Calcium etc..). I just wanted to pick an oil which has API SP test requirements label and an ACEA A3/B4/C3
ACEA A3/B4:
API SP:
Absolutely irrelevant! You want MB229.5, BMW LL01, VW 502.00 etc. Those approvals FAR exceed anything API.
What is even this thread about :ROFLMAO:
Plenty of newly formulated ACEA oils meet or exceed API SP
Just a question of how new bottle you will get in the stores.
Have you compiled a list of oils that meet both certifications?
The problem is there aren't many XW-30 updated ACEA 'A3' formulations in US
I've google for VOA/UOA on the oils below.
Let me know if you know any.
New 'SP' detergent formulation (Calcium PPM <1800 ):
Mobil1 5W-30 FS
Old detergent formulation:
BMW TwinPower Turbo 5W-30 LL-01
Castrol EDGE Euro 0W-30 A3/B4 --> I like this oil a lot. Lot of PAO
Castrol EDGE Euro 5W-30 A3/B4
Pennzoil Euro 5W-30
Pennzoil Euro AV 5W-30
LiquiMoly Special Tec LL SAE 5W-30
Valvoline Euro 5W-30
Motul 8100 X-CESS 5W-30
Nope, as you know, ACEA is just a starting point for manufacturers. But, I am not sure OP knows that.
You can clearly see that vanilla ACEA A3 doesn't have any test that counts 'LSPI' events unlike API SP/ACEA A7
Daimler 229.5 does have an LSPI test but the specs are unclear. All the oils above have 229.5 approval
I am not debating which OE has the best approval. I said, I would like to use the best available formulation. A3 + 'SP' compatible detergent.
If you read a lot of STLE/Tribology research, the consensus is clear about calcium being a factor in LSPI.
You are right that ZDDP negates LSPI but only when present in very high quantities (not feasible in PCMO)
LSPI seems to be super-overhyped… we’ve had the discussion here and so far the consensus is that not one member on here has personal or provable 3rd-party knowledge of even just one instance of engine failure due to LSPI (unless they don’t want to be THAT guy, lol!).
Moly is also an attenuator of risk, and so are lower-volatility base oils.
Very high VI oils are also historically poor performers on Noack testing, which means more oil vapors entering the combustion chamber, and hence a contributor to conditions favorable for LSPI.
Mobil1 5W-30 FS
Pennzoil Euro 5W-30
In the European section, you have numerous posts that list MB testing requirements.
You can actually go ACEA C3 that has MB229.52 approval (Mobil1 ESP 0/5W30) that does have LSPI test.
Generally, European manufacturers do not have LSPI issues in engines. LSPI is product of sloppy engineering, lower calcium is just band aid. All BMW approvals have more stringent timing chain tests, MB is generally considered as gold standard bcs. overall testing requirements.
If you want really good oil or best off-the-shelf oil, you go with Euro-approved stuff. Otherwise, you are chasing your own tail with this API vanilla stuff.
Porsche A40 for me. It covers everything! And now in the U.S, most are API SP for those who care.
Castrol (BP British Petroleum) euro 5w40 has an a40 approval from Porsche and Bmw LL-01 approval. On sale 5 quart jug for $24 at wally world. Made in New Jersey. Excellent protection from nasty gdi blow by acids and viscosity stays in spec up to 10 k oci.
For 250*+ oil temps there’s no way you could pay me to run M1 AFE, which very rapidly and permanently thins out by design. Do your engine a favor before you go to the track and fill it with M1 FS 0w40, never anything with “fuel economy” or Resource Conserving in the name.
I could be wrong , but I believe focus here is with the M1 0W30 ESP and other brands 0W30 Euro rated oils (more robust than M1 0W30 AFE) . Regarding M1 0W40 FS , it doesn’t stay at a 40 weight for long sheering down into 30 weight territory quickly . Still a very good and popular oil here.
Ow- spec is compromised, gun put to the head of manufacturer by the EPA to meet "fuel conserving" .
Only needed to get you through cold 25°F beliw zero max 5000 max oci as it breaks down too much. The manufactures warranty tops at 50,000 mile, just enough to make it until that 0w spec killed their engines, hoping to then sell a remanufactured crate engine.
I want my Mobil-1 0w40 Euro to fall between 11-12 cst. That's good news for the 2.4 GDIs we own. Even if it finishes my 3k OCI above 10, I'm fine with it.
You can use a HPL 30w and finish in the 10+ neighborhood. That's what I'm trying now with a blend of HPL 5w30 Performance Plus and 10w30 HPL No VII oils.
Rather than mixing, the No VII Euro 5w30 ended up in the 12.7cSt range (after starting at 11.19) in my EcoBoost over 14.4k miles. If you’re going to mix No VII with VII and end up with a 10w30 anyways (winter ratings do not “mix” like viscosity does), why not just go with the SuperCar 0w40 or HDEO CK-4 5w40?
Those are a little more in line with your thoughts on your HK requiring additional viscosity, and don’t require playing backyard mixologist. 👍🏻
Never change, Sir.
