Help Me Decide on Oil for new 2024 Elantra N
Dickson, TN.
Well, I had a 2016 WRX and decided on Pennzoil Platinum 10W-30 because of relatively low SAPS (to help keep valves clean), low Noack, and excellent GTL base oil. And the ability to obtain it from Walmart’s shelves at will.
Things were a bit more simple back then, as we were dealing with API SN, I think, and most of the Euro formulations still had really high SAPS, and LSPI was getting more into the consciousness of the drivers of performance sport compacts as something that should be avoided.
Now, I will say, I do have an understanding of the potential impact of calcium in the oil, on LSPI, but I also know how to avoid getting the engine into the regime where LSPI is a risk (lower RPM, higher gear, spiking boost).
But anyway, the car will be driven hard on backroads and mountain roads regularly, and has 276 HP/289 FT-LBS (and I’ve read that that is a conservative rating, because the car actually has been dyno’d to produce those numbers at the wheels, so it’s actually very conservatively rated from the factory), so I’m thinking something with at least 3.5 HTHS.
So that rules out the owners manual suggestion of an ILSAC 0W-30. So if you’re here to tell me to “just follow the manual”, don’t waste your breath! 😜
M1 ESP 0W-30 (SP version): Maybe? It would simplify things, because I am already using this in our Odyssey. However, it’s been brought to my attention that it has ~ 1700 ppm of Ca. Not overly high, and this oil passes the MB 229.52 LSPI test. However, some believe that this is still a little high for a smaller TGDI engine. And @RDY4WAR made the point that we don’t know MB’s test specs, or what engine they’re using for the test.
ESP 5W-30 has much less. It’s just $11 more per jug ($38 vs $27). But it should have fewer VII/VM, and lower volatility. This is probably number one in the running right now, especially as I can get it on the shelf at the local Auto Zone.
But then the SP version of M1 FS 0W-40 also has a new lower Ca detergent pack. But higher SAPS… Wondering about potential for more deposits due to higher SAPS on this one, or other API-SP-approved Euro formulations that would have good HTHS, great base oils, but maybe higher SAPS.
Manual calls for 6000-mile OCIs, but I'm planning on 5000 mile OCIs.
Funny note: There’s a decal under the hood that says “Hyundai recommends Quaker State”. But QS doesn’t actually even offer a 0W-30! 🤣
I emailed them, and they didn’t have much to say other than QS doesn’t offer an oil for my car, and to take it to the dealership! 😆
I’m also open to considering a boutique oil like HPL - I’ve never used a boutique oil, but I know a lot of y’all do, and I have looked into it a little bit and obviously the specs are very, very impressive. The “no VII” versions are especially enticing, especially with this being turbo, and wanting to avoid deposits both in intake tract and turbo. But is it worth it when I’m going to do 5000 mile OCIs?
Looks nice, I don't know about the big dealer label on the left though. I'd use anything with porsche A40, bmw ll-01, and an SP rating is what I'd use. Use what you're using in your Tacoma. Change it every 4 or 5k.
I would consider Pennzoil Platinum ACEA C3 oils as well, Euro L 5W-30 and the Euro LX 0W-30.
Any of the three M1 choices you mention should be fine. I wouldn't have any issue using regular Mobil 1 5W-30 or 10W-30 either.
Do you have any idea about oil temps for the engine?
Nice ride man, I want to buy one of these in a few years when my Camaro is paid off and I need a ride for my newborn. Is it manual or dual clutch? The refresh looks 100x better.
I would go with anything HTHS 3.5. Even the new M1 0w-40 is API SP. Even though its full SAPS, it should be fine for the Theta II turbo. If you want mid SAPS get the autozone deal for M1 0w-40 ESPx3 (i think it is x4 now). That one has Porsche C40 approvals, and its one of the top mid SAPS oil out there now. I run it in my Camaro 6.2. Main reason for mid SAPS on those now is Porsche has GPF for Europe, not really necessary without GPFs.
Quaker state has had 0w-30 lx for a while but it's the same as Pennzoil euro lx 0w-30.
This is what the web says 5.49 US qt. SAE 0W-30 API SN PLUS/SP or ILSAC GF-6.
Basically any euro oil with an lspi friendly formula which started with sn plus.
This is from the owners manual. It says 0w-30 should be used for best fuel economy but that "higher viscosity engine oils are required for satisfactory lubrication in hot weather" I believe manufactures need to state the grade they tested fuel economy with and not provide anything else explicitly but that doesn't mean they can't try to sway you into using thicker which they all put some form in one way or another.
Cool new sled ! I ended up buying a Type R, but the EN was definitely on my shopping list. I'm running PUP 5w-30 in my CTR currently, but it seems I'm constantly going back and forth on trying to decide what oil to run.
I’m also open to considering a boutique oil like HPL - I’ve never used a boutique oil, but I know a lot of y’all do, and I have looked into it a little bit and obviously the specs are very, very impressive. The “no VII” versions are especially enticing, especially with this being turbo, and wanting to avoid deposits both in intake tract and turbo. But is it worth it when I’m going to do 5000 mile OCIs? View attachment 231685View attachment 231686View attachment 231687View attachment 231688View attachment 231689
Essentially any euro oil (full or mid-saps) on the shelf today meets the performance requirements of API SP.
M1 ESP 5w30, 0w30, 0w40.
Pennzoil Euro L 5w30.
The M1 0-30/40 would be fine, as would the. 5-30. Saps isn't that big of a deal unless the engine is using a slight bit of oil. LSPI usually isn’t that much either. Use what you are comfortable with. But I gotta say one thing, nice car, but dude, that giant “Hyundai of the Shoals” has got to go!
Yeah, literally just got the car Thursday.
They delivered it to my house (bought it sight-unseen from a dealership 2.5 hrs away in Tuscumbia, AL).
I couldn’t believe they plastered that decal on the car. After all, this isn’t your run-of-the-mill Accent/Excel/whatever.
I will definitely be saying something about that in the survey.
Oh well, at least it’ll come off.
Doesn’t look like the Euro LX (either branded QS or Pennzoil) is very easy to get anymore.
I think if I were going the route of ordering oil, I’d be going boutique, and probably HPL.
RE: Oil temps - I’ve only driven it for a total of about 30-40 min on backroads. During stretches where I was keeping RPMs up a bit, oil temps got into the low 220°F range.
Comparing to my 2016 WRX (similar engine - turbo 2.0 TGDI, somewhat lower output), it seems pretty normal.
Highest I ever saw the WRX get, when really pushing the car on mountain roads, was brief periods of high 230° - low 240°F range. And it would go down pretty quickly after driving at more sane RPM for a couple of min.
But I would say 230°F range would be reached fairly often on a warm day in the mountains.
Thanks dude. It’s 6MT. Only way to go IMHO. Even though I know the DCT is faster, I just love rowing gears!
Is the X3 really considered mid-SAPS?
Looking at the VOA, it still has really similar amounts of ZDDP, and it’s still running close to 1700 PPM Ca, whereas the standard API-SP M1 FS 0W-40 is running the Ca/Mg detergent pack.
Yes, I do like the fact that they include that language in the manual to allow the owner some latitude in oil viscosity grade choice, even though, as you can see, it’s not at all cut & dried, and is quite contradictory.
Thanks, but I think I do prefer something with a bit lower Ca.
I think I’m leaning pretty strongly towards my original thought - M1 ESP 5W-30.
And then getting some UOAs done to check how it’s protecting.
You may be right.
I’ll certainly try not to lug it. I think lugging a TGDI engine is when you’re most likely to provoke LSPI.
Main reason I’m thinking mid-SAPS is to try to keep the intake valve deposits at bay for as long as possible.
And, yes, RE: the decal, as I was saying to someone else above, I cannot believe they did that to that car!
At least I will be able to get it off fairly easily.
Might also debadge the backend (remove “Elantra”). Haven’t decided yet.
Nice. X3 is dexos2, so should be <=.8 SA.
X4 isnt dexos2, but dexos2 is being phased out anyway. I'm pretty sure the formulation is the same.
Consider a new #1 Choice
Mobil-1 Euro 0w40 in SP. Sold (I think? exclusively) at Walmart.
If you get overly worried about 0w40 oil receipts for Hyundai, go with the Pennzoil Euro LX 0w30. Many Hyundai dealers stock this one.
If at any time a little consumption with it shows up, switch to Mobil-1 0/5w30 ESP.
