It looks like the API/ILSAC and ACEA specs have converged in many protection requirements with API SP/RC (ILSAC GF-6) and ACEA-2021. The legacy ACEA categories (A3/B4, A5/B5, C2, C3, C4, and C5) still lack LSPI and timing-chain wear protection and provide inferior valvetrain wear protection than API SP/RC (ILSAC GF-6) does. However, the new ACEA categories (A7/B7 and C6) provide LSPI and timing-chain wear protection and provide the same valvetrain wear protection as API SP/RC (ILSAC GF-6) does.
First, some background on how ACEA-2021 was developed:
www.infineuminsight.com
Excerpt:
_________________________________________________________________________________________________________________________
The Sequence IVB stands out as it is not meant to be a direct successor of any particular test but rather to fill the gap the TU3 left behind half a decade ago for a gasoline valvetrain wear test. The Sequence IVB is on Toyota hardware and has been developed for API SP / ILSAC GF-6. There is significant debate in AAA about suitable Sequence IVB limits for the ACEA Sequences. The starting point was to carry over the API SP limits, however, industry data gathered on representative ACEA oils suggest API SP limits are not appropriate as they would exclude about 50% of the tested ACEA lubricants with known good field performance.
The Sequence IX LSPI test is well known in the industry, it was developed on Ford hardware for the API specifications and was first introduced to API SN Plus. Its introduction into A7/B7 and C6 is planned at API SP limits, which is supported by all stakeholders.
The A7/B7 and C6 chain wear requirement is also specified by a test developed on Ford hardware for ILSAC GF-6 - the Sequence X. There are similarities to the Sequence IVB in the sense that the introduction at the proposed API SP limits would rule out 50% of the lubricants represented in the industry data gathering mentioned above. Discussions are ongoing about how to define limits appropriate for ACEA lubricants, which are subject to different chemical constrains than API lubricants. All parties agree with the need for chain wear protection. However, given the fact that gasoline direct injection engines have been the predominate gasoline technology in Europe for almost a decade, questions arise on how much additional protection is needed. One party not being prepared to give any compromise on the limit makes finding a mutually agreeable limit look unlikely.
ACEA-2021 was finalized and released in 2021. Here is how the ACEA-2021 specs compare to the API SP/RC (ILSAC GF-6) specs:
Valvetrain wear (Sequence IVB, ASTM D8350, Toyota 2NR-FE):
OEMs can add their own tests and chemical/physical specs such as Noack, like GM dexos1 and various Euro-OEM tests, making the protection better or more vehicle/OEM-specific. Nevertheless, the current ACEA and API/ILSAC specs show that the API/ILSAC and ACEA specs now have more or less converged, and the legacy ACEA A3/B4, A5/B5, C2, C3, C4, and C5 specs have already fallen behind API SP/RC (ILSAC GF-6) in some protection requirements.
The reason why the legacy ACEA categories (A3/B4, A5/B5, C2, C3, C4, and C5) provide less valvetrain-wear protection than API SP/RC does and provide no timing-chain wear protection is because half (50%) of the existing legacy ACEA oils failed to pass the valvetrain wear test at the API-SP/RC limits and another, different half (50%) failed to pass the timing-chain wear test at the API-SP/RC limits, and ACEA compromised to agree with the Euro OEMs to lower the bar for valvetrain wear and omit timing-chain wear protection altogether, even though the latter test is crucial in TGDI engines. Note that virtually all legacy ACEA oils include some Euro-OEM approval, and these Euro-OEM approvals did not help these legacy oils to pass the valvetrain and timing-chain wear tests. However, if a legacy ACEA oil also carries an API-SP approval, it will ensure that it will provide the highest valvetrain wear, timing-chain wear, and LSPI protection.
Infineum Insight - ACEA revisions coming soon
As the revisions to the ACEA Oil Sequences near completion, Uwe Zimmer, Infineum Industry Liaison Advisor reports on the unprecedented changes that have been made on the light-duty side and what they might mean for future lubricant formulations.
Excerpt:
- API SP/RC: ≤ 2.7 mm³
- Legacy ACEA A3/B4, A5/B5, C2, C3, C4, and C5: ≤ 3.3 mm³ (22% more wear than in API SP/RC)
- New ACEA A7/B7 and C6: ≤ 2.7 mm³ (same wear as in API SP/RC)
- API SP/RC: ≤ 0.085 merits
- Legacy ACEA A3/B4, A5/B5, C2, C3, C4 and C5: not tested, not certified for TGDI timing-chain wear
- New ACEA A7/B7 and C6: ≤ 0.085 merits (same wear as in API SP/RC)
- API SP/RC: ≤ 5 events average and ≤ 8 events per iteration
- Legacy ACEA A3/B4, A5/B5, C2, C3, C4 and C5: no test, not certified for LSPI
- New ACEA A7/B7 and C6: ≤ 5 events average and ≤ 8 events per iteration (same limits as in API SP/RC)
- Same limits in API SP/RC and all ACEA
