I put a few Mobil 1 API-SP oils into the HTFS/VII calculator. They don't provide HTHS in the PDS, but I can estimate it by adjusting it so that the base-oil viscosity index (BO VI) ~ 135.
That said, most API-SP Mobil 1 oils have a reduced VII content and a higher HTFS viscosity (high-temperature, full-shear viscosity = base-oil + additive-package viscosity at 150 ℃) than their API-SN counterparts. This is a good thing, as less VII results in a cleaner engine, and a higher HTFS results in less engine wear.
There was at least one exception. They increased the VII content and thinned down the base oil in Mobil 1 Extended-Performance (Mobil 1 Extended Performance) 0W-20 quite a bit, which is unfortunate because the API-SN/SN PLUS version was an excellent oil that was mostly PAO.
You can find the HTFS/VII table and the background behind it here:
https://bobistheoilguy.com/forums/threads/htfsv-high-temperature-full-shear-viscosity.307409/
