First post--been lurking for a while--have learned a lot.
I have a '02 Mazda Protege 2.0L engine. Manual calls for either 5w30 or 10w30. I'm at 70,000 (got the car at 45K, 2nd owner) on the engine and 8,500 miles with ASL 5w30 / EAO filter (mostly winter driving) and will drain and do a UOA. Have burned a tad, I think, but have not added any oil.
First run of Amsoil; used Mobil 1 5w30 the two changes previous to ASL--first change at 5k, 2nd at 7500. Didn't burn any with the Mobil 1 but wasn't doing the high speed commute then, either. Blackstone said #s and TBN all OK. Anxious to see the results on the ASL--car seems to like it better than the Mobil.
I do a lot of freeway commuting at 65-70 mph, some stop/go. Is the Amsoil SSO suitable for this car? This is a high-reving engine and I grind away at 70 every day for about an hour. . . .
I learned here that there's a lot of good oils and each can be different in each car--any advice/thoughts are welcome on this car, though. I'd like to take the car out to 200K or more and like long drain intervals but don't want to push it.
Thanks in advance--
PJP
Thanks in advance--
PJP
