Oil analysis doesn't tell you wear performance, only tear-down testing can provide you with that. UOA's widely misunderstood and misused. If you haven't read the article on them by Doug Hillary, I highly recommend doing so:
https://bobistheoilguy.com/used-oil-analysis/
The negative characteristics of PAO (seal shrink tendency, poor solvency) are easily counteracted by coupling it with AN's and POE, that's the whole purpose of a balanced blend, capitalize on the strengths of the components while cancelling out their weaknesses.
Group III HC also has poor solvency, it's basically just as bad a PAO. The difference is that it doesn't require the POE to balance out the seal shrink. But, PAO has cold temperature performance that Group III can't touch.
Ultimately, it depends on what you need the product to do. I have periodically started when it is -30C, a PAO-based oil has readily observable advantages in that scenario, particularly consistency, because it isn't beholden to PPD's for its cold temp performance. If you aren't doing extreme cold starts, then it doesn't really offer much (perhaps a bit better oxidation resistance) over Group III.
