Not saying it *will*. Saying it *can*. And if it did, it's almost certainly so minor nobody would care. Like, it's the difference between your cats being plugged or poisoned at 200k instead of 250k miles.So you're saying that an engine with low tension oil rings consume more oil if I use a higher grade? How high?
My Tiguan has low tension oil rings I believe, but it consumes less of a Euro 30-grade than it does a 20-grade. I just don't see it.
That level of thing.
The only reason I mention it is because a lightly driven car seeing only seasonal use is one of the few cases where it could potentially matter that a thicker oil might be slightly too thick. It won't be giving the pistons the temperature and pressure they need to seal optimally and scrape oil efficiently.
Again, quibbling little theoretical concerns that in the real world amount to basically nothing. But this is BITOG, where we specialize in making little insignificances into big points of concern, so I thought I'd mention it.
