I really miss the true Full sized cars
Originally Posted By: SteveSRT8
A full size car with a turbo 4 banger?
Not in my garage...
I agree. I saw a full size Cadillac sedan that said 2.0 on the back. Didn't the 80's era Ford Escorts have 2.0 4-bangers? I couldn't imagine that tiny engine lasting very long pushing a huge sedan around.
Originally Posted By: TFB1
Originally Posted By: Benzadmiral
The only car I had that fitted into this category was the '65 Mercury Park Lane, with the rear power window (the "Breezeway" option) so that, if you opened all the windows, including the triangular vent windows, you could cruise on a warm day without the A/C. But it had good air, a 300 hp Thunderbird engine, and was easy to work on -- and got about 15 mpg on the highway in a time of $1.10/gal. gas.
No, it wasn't as reliable or safe as modern cars. But a fun ride nevertheless.
Before the 1972 models, almost no vehicle had the rated HP, that 300 Hp 390 T-Bird engine may have had 225, and that's on a good day(I had same in a '64 Galaxie, two in fact)... The 455 Buick GS did make approx their rating of 360, left the 454 Chevy boys wondering how a heavier vehicle with less HP was mopping up on their 450Hp LS6 at the drag strips(Chevy was lying)..
Yes...but not the way you think. Actual dyno tests of LS6 engines have shown they made 450HP easily...and usually 500+.
Quote:
Starting 1972 Fed says HP will be rated as installed in vehicle, cork screw exhaust and all... Along with reducing compression and smog tuning, that's why most of the '70s models appear to have such dismal HP ratings, but in the real world the '72 may have had 10% less HP than the earlier vehicles... With headers(mfgr always rated with headers or at least open exhaust), a re-curve of distributor and carb rejet, there was 300Hp in those T-Bird 390, it just couldn't get out...
Correction factor also changed (that dropped everything ~5%). Also, GM dropped compression ratios about two full points across the board for 1971.
Originally Posted By: HangFire
On top of bogus OEM HP claims, Car and Driver admitted to bogus 0-60 and 1/4 mile times. Theirs were always a hair faster than Road & Track. There was a lot of delusion going on.
Many press cars were ringers. I recall a magazine writer buying a former press-fleet Firebird. A few years later, he discovered it had ported heads, a recurved distributor, and an aftermarket cam. GTO's having the 389 replaced with a 421 weren't that unusual.
Another example is the 302 in my '72 Comet... the '71 was rated 210Hp, '72 plummeted to 140Hp, again mostly because of the soda straw exhaust system that was same both years...
Yes, cars really started to suck around 1972.
John DeLorean was no doubt the sly one...
There was at least one case the testers(can't remember which mag) received a GTO with engine ID stamping on block that was altered... They tested it and it apparently ran really good times but would not publish the numbers... A couple years prior mags were patting Pontiac on the back for sending "properly prepared cars"..
No, not really. Power was respectable for many (except GM) to 1974. (Offhand, Chrysler's 1971 and 1972 engines were identical.)
This was also documented in Car and Driver during their infamous test of the Pontiac GTO versus the Ferrarri GTO. John DeLorean was known to send out tuned cars.
I think it was much more the norm than we were led to believe...
Having owned a real LS6 Chevelle for several years as a kid I can promise you it was very powerful. Mine had well over 200 passes on it and never broke into the the twelves even with mods.
My much heavier Chrysler easily demolishes it with full luxury and only 6.1 litres. Cars today are not even comparable to the "good ole daze". They are light years better...
Not in my garage...
Was it a Cimarron?
Not in my garage...
Was it a Cimarron?
2.0T is the base engine in a CTS...but also the base engine in a BMW 5 series.
