Oh yeah, I’m not spending anything, other than to make sure that the Freon charge is correct. Many reputable companies will come back warmer weather when a system is installed during the winter to recheck levels. Last I knew anyway, but not this company.You can spend a lot of money trying to get just a little bit better.
Probably not worth it.
Your circulation feature may actually cost more than running the fan full time.
A lot of energy is used starting the motor 2-3 times an hour.
But we are discussing comfort...not energy savings.... and probably not enough to really matter.
Wear and tear are a moot point.
Indoor fan motors are very robust...they last forever.
In commercial settings you run them 24/7/365 and they still last forever.
Factorytuned definitely seems to be in the more uncomfortable comfort level, and by the sound of it, he might be considering spending some money on a dehumidifier.
I certainly can understand the frustration. As I found out two weeks ago, we are definitely on the edge of marginal, but definitely acceptable. I was surprised to see the unit running one day and the temperature actually go up 2° from its setpoint but those conditions rare for our type of use.
I do look forward to verifying the Freon levels and the pressures, I’m on the fence if I buy the gauges and free on myself or just have somebody check it. Past experience, I will probably one day maybe not even this year buy my own gauges. Before we moved into this house last year, I left my old gauges and a tank of Freon r22 with my neighbor at our old house since I had no use for it in the new house.
There might be a misunderstanding with the circulation feature. If during the night the unit doesn’t turn on in one hour. The thermostat will turn on the fan for 20 minutes to circulate the air in the house, which is a terrific feature and in reality you do save energy, making the main part of the house colder so the bedrooms don’t get too hot if I’m explaining that right. If the AC unit does turn on the amount of time it runs is then subtracted from the 20 minutes that the fan would have turned on for without Cooling.
Just stopped in to take a break from washing the house
I also just did this with the terrible Apple text to speech on my iPhone so excuse any typos, but I have to get back out to washing the house
