@factorytuned2012
AS you know the Humidity reading on your thermostat made me curious so I bought a meter in Walmart. It's only about $14 and maybe you want to check it against your stat. Kind of neat, records high and lows over 24 hours.
Right now I am at a high because it went from 72 degrees sleeping to the current 77. So the AC have not come on for hours, it will shortly now that the house made it to 77 daytime. (though when home we typically put it at 76, I forgot until just taking this photo)
Anyway, bottom line is with AC running we are always in the middle 50% and most all times lower. AS you can see, despite the rain last night and today. It was down to 48% with the system running. I think it may be worth looking further into if it turns out your stat humidity it correct.
Maybe a major intake leak or something in the attic. Dont know.
Again, this current 57% peak is only due to the system not on for a few hours of this rainy day. It takes a while climbing from the sleeping temp of 72 to get to 77 before the system turns on again. IN the meantime humidity increases until it does. Once the system starts cycling on and off it drops surprisingly fast. I think I can see why now, with the new building standards and windows/insulation, even the insulation about the flex ducts is higher how for our house the 2 ton unit seems to be right.
My son with a 20 year old house in the update of SC as noted has a 2.5 and a family member in N. Myrtle has a 3 ton unit all homes about the same square footage. I suspect your AC guy was correct and maybe needed a 2.5 ton.
As I have been carefully watching our own system now because of what I thought was a past issue and reading about yours. I was telling my wife last night that we seem to be running correctly here.
I wasnt going to post the photo below because it was out of "normal" We were out on the boat yesterday, since our thermostat was set at 82, little did I know there would be an "energy savings adjustment for three hours) So even with a peak of 84 degrees on a HOT sunny day our Humidity never went above 52% For most the day the unit didnt turn on until the "energy savings event" was over. By this time I was home and I was noticing a 3 to 4 degree drop per hour. (if I remember correctly) that is when I said to my wife that we are good with the system.
I cant help wonder why your humidity is so high compared to ours unless the meter I bought is bad but I think correct. Our house feels dry too. I wonder if something else is in play and why I thought maybe an attic duct leak or something... Im clueless but I like puzzles.
