Sure I have but it don't change the fact that it is a 20grade oilRespectfully have you looked at Ready4War used oil analysis?
I have vehicles that are easy on oil. Other than that I have no honest answers
Sorry, it's not clear what you are trying to assert here? The grade, 10W-20, is a legitimate SAE grade. The oil may thicken a bit in service due to its inability to shear, due to a complete absence of VII polymers. If left to thicken enough; if kept in service long enough, it's possible it would oxidatively thicken out of the SAE 20 grade range and into that of SAE 30.So we make up a grade to a oil because of what may or may not happen to an oil.
will the HTHS of the oil increase along with it why do we label oils of what they are than.
Do we see a increase in HTHS of the oil in this thickening process.Sorry, it's not clear what you are trying to assert here? The grade, 10W-20, is a legitimate SAE grade. The oil may thicken a bit in service due to its inability to shear, due to a complete absence of VII polymers. If left to thicken enough; if kept in service long enough, it's possible it would oxidatively thicken out of the SAE 20 grade range and into that of SAE 30.
ALL oils are subject to oxidative thickening if kept in service long enough. Most inexpensive PCMO's follow a trend of viscosity loss due to shear followed by viscosity increase due to oxidation. Ideally, the blender plans for oxidative thickening and viscosity loss due to shear to cancel each other out, but once you add in fuel dilution and engine design, most often that's not the case and we generally see viscosity loss overall with value-oriented PCMO's.
Oils that use higher quality VII polymers (and less VII polymers) will be less likely to shear and more inclined to demonstrate oxidative thickening. This will be more obvious in applications without significant fuel dilution.
So what I betting HPL don't make a single oil that is not shear stable but they will still take on fuel. I could possibly careless what you ever run in a vehicle.
Yes, you'd see HTHS increase too, since there's nothing to temporarily shear, so HTHS visc would increase as KV increases.Do we see a increase in HTHS of the oil in this thickening process.
This is what my K20 is getting when track weather starts this year.2.742
Do you think this is due to thickening counteracting it and/or because fuel directly affects the VI polymers? I think the former is certainly true and I’ve heard some people mention the latter, but there was no scientific explanation or evidence provided.With no VII though, it better handles the fuel as well.
Delvac 10w30 Super FA-4/SN
40C 64
100C 9.8
HTHS 3.1
VII free?
How about Delo SD 15w30? The perfect oil that nobody bought.
The worst oil ever blended. If it was “perfect oil” everyone including you would have bought itDelvac 10w30 Super FA-4/SN
40C 64
100C 9.8
HTHS 3.1
VII free?
So the No.VII oils are their "top notch" tier? What is "better" about them than the regular PCMO? If there is a thread about this let me knowOxidation and zero shear.
No, they were formulated specifically to be VII free, that doesn't mean they are the best performing product line. Their higher tier VII-containing oils (star VII) are basically shear-free as well, but may perform better. As @High Performance Lubricants as noted on here in the past, incorporating VII's can offer performance improvements.So the No.VII oils are their "top notch" tier? What is "better" about them than the regular PCMO? If there is a thread about this let me know
There are many grades that can't be formulated without VII's.Why isn't No VII just their "normal" oil if it's better?
