mjoe; sometimes I wonder if using the Prestone Extended Life; as I am currently, is causing more wear related to the aluminum parts in my engine(yes, it's mostly an aluminum engine I know).
Other than that(wrong fluid for vehicle), your oil choice of correct grade may impact certain wear numbers, but actual/measured wear over the course of an engines life is like the chart shows previously but if as proposed represents 'initial' fill of fresh oil increasing wear within 1,000-1,500 miles I just won't change that frequently.
On the other hand, someone mentioned earlier that too many people don't get their oil changed often enough.
Well, if that's true it wasn't because the 3,000 mile brainwashing overkill wasn't known.
