Originally Posted By: Gunner14
I'm the guy who started this post... Sure has been many ideas, opinions, and data posted. Because of all the interest, I decided to directly ask a friend who is a chemical engineer and has worked in the petro industry for years. He contacted me today and said he would forward some abstracts/summaries of actual studies completed by some large manufacturers of automobiles and engine oils. If I get his permission, I'll provide access to those actual documents.
His take on oil changes:
Best indication for an oil change = analysis - as the actual ideal OCI will be particular to the engine and the oil and the conditions as used; oil detergents and "base(?)" additives stabilize during the first 250-500 miles of use in 99.9% of all commercially available engine oils due to the complexities caused by the engine heat cycles, and are specifically designed to do that by the manufacturers; changing engine oils all-the-time in intervals shorter than 500 miles can be quanitatively deterimental to the long-wear picture of an engine (i.e., the detergents compete with the wear additives higher during this period); 3000 mi oil changes are usually excessive given the current oils and the new engine designs and tolerances (rate is less for metals released in oils as today's engines wear); changing your oil at 3000 miles may waste $$$, but not harmful - as wear is only slightly higher during the initial 250-500 mile period post an oil change (he emphasized that in a few of the studies he has reviewed, the wear was not "meaningfully" or "measurablely" higher even during that first 250-500 miles with the new oil).
I have tried to summarize what he said as I remembered, but they are not exact quotes.
Nice info, thanks for posting! You mention this: " as used; oil detergents and "base(?)" additives stabilize during the first 250-500 miles of use in 99.9% of all commercially available engine oils due to the complexities caused by the engine heat cycles, and are specifically designed to do that by the manufacturers; changing engine oils all-the-time in intervals shorter than 500 miles can be quanitatively deterimental to the long-wear picture of an engine (i.e., the detergents compete with the wear additives higher during this period"
Would an extended drain have more of a negative impact during this initial period, and would the amount of miles needed for an extended drain oil to stabilize be more? Thanks
