Hi all,
I'm struggling to find a product data sheet with ZDDP listed, or VOA for Valvoline Synpower 10w40.
Their PDS shows TBN as 9.3 but doesn't mention ZDDP: https://go.lupinsys.com/valvoline/h...16cf6d/search_api/SynPower_5W-40-PI_Sheet.pdf
The closest I've found is a very helpful member here that posted their Synpower 5w40 results for the past three years:
The readings average to ~900ppm Phosphorous and ~1,000ppm Zinc.
Speedway motors have slightly lower reading, 750p / 950z
https://static.speedwaymotors.com/images/SMI-Oil-Chart.pdf
In the PDS it states:
Wear protection
Their spiel:
"SynPower is specially designed for vehicles requiring a high performance full synthetic lubricant. It’s unique anti-wear, detergent and dispersant chemistry minimises wear and keeps your engine factory clean for longer engine life. Designed for high performance application 4, 6, V6, V8, naturally aspirated, supercharged & turbocharged engines."
I wonder if Synpower is for modern pushrod V8's i.e. roller cams, as opposed to older flat tappets V8's, hence the seemingly higher zddp content (above ~800), but not the ideal ~1200ppm that's usually mentioned, hence it sitting in the ~1,000 range.
Application:
I'm curious how this would be for a flat tappet engine. Specifically:
Regular street use.
My main concern is making sure it's well protected. Is the oil likely up to it?
I know ZDDP isn't everything - Boron and Molybdenum can also take the place where zddp is lower, if I have understood that correctly? i.e. same protection with lower zddp due to more boron/moly. Only, the PDS doesn't list the amounts (the UOA from the above member do show the amounts though).
Alternatives:
Being outside of the U.S, I don't have access to several of the go-to's (Penn etc.), or they are very expensive due to shipping. In fact, I used to use Driven HR which was priced the same as my daily driver oil. But shipping costs have increased across the board and as such, Driven is 50% higher than what it used to be.
- 2021: https://bobistheoilguy.com/forums/t...-5w-40-a40-porsche-911-997-5900-miles.338869/
- 2022: https://bobistheoilguy.com/forums/t...-5w-40-a40-porsche-911-997-4400-miles.361496/
- 2023: https://bobistheoilguy.com/forums/t...-5w-40-a40-porsche-911-997-4700-miles.375378/
Wear protection
- Zinc additive package provides tough anti-wear protection. Excellent wear protection enhances engine life without adversely effecting emissions system
Their spiel:
Application:
- 1970's 318 Dodge, completely stock
- 1970's 350 SBC, stock or potentially has an RV cam (still in the very mild category)
Regular street use.
Alternatives:
- Valvoline VR1
- This is a viable option here, except my understanding and from reading their PDS, it is not intended to stay in the crank case for long. It's ideal for a few weeks / 500 miles, by their recommendation
- Valvoline Maxlife 10w-40 API SN, SM/CF | ACEA A3/B4
- ZDDP levels appear to be lower than Synpower, for Maxlife they work out at ~770z/850p
- TBN: 10
- That suggests that likely the better of the two is Synpower, in terms of zddp pacakge
- Shell Rotella
- A controversial one, whilst it meets the zddp numbers, I'm shying away from it due to it not being recommended for non-diesels due to the high detergent package... from what I've read
