It may or may not be in the owner’s manual. Also look under the hood for a sticker.For all the comments above Angie is at work in the car, with the owners manual
I’ll have to look when she gets home, thank you for your recommendation and knowledge
Tool makes no difference. The plugs are designed as a 1 time use plug. The tool simply unscrews the plug from the center.Speculating that the drain plugs can be used more than once? Or that a tool makes it easier and less likely to damage the plug?
What should we beware?
What if I tripped and fell into a bunch of Valvoline nonsyntheticIt's a non-high output 2.0T post 2019. It's 508/0w20. It's basically impossible to pick the wrong euro oil, unless you somehow tripped and fell into a pool of 0w8 TMO.
Okay sure. Go for it.Tool makes no difference. The plugs are designed as a 1 time use plug. The tool simply unscrews the plug from the center.
that's not euro oilWhat if I tripped and fell into a bunch of Valvoline nonsynthetic![]()
So much confusion on approvals when it’s something that’s intended to simplify, not make it more difficult.that's not euro oil
it's very simple though. any oil approved for the spec on the car is totally fine.So much confusion on approvals when it’s something that’s intended to simplify, not make it more difficult.
Again, do you have tube? If so, purchase one for A4 B8.Can someone guide me to a dipstick,I want to purchase one,thank you
Yes I have a tubeAgain, do you have tube? If so, purchase one for A4 B8.
FCP Euro, ECS Tuning are go to online shops.
Once you are out if warranty, switch to VW504.00/507.00 oils.
It’ll probably be traded in around 80k milesYes I have a tube
Go to those web sites I mentioned or just use google.Yes I have a tube
That bump often breaks or gets worn down.
Its designed to "ramp" in to lock but to break off when removed. It's sloped on the install side but square cut on removal.How 'often'? When did it break? During removing or screwing in?
Let's assume that it doesn't break during trips.
I use a magnetic plug and only replace the O-ring every 2nd time.
Elring (OEM) sell them in sachets. No issues so far.
My very 'special' tool? A plastic coin (trolley token or play money).
Fits smoothly.
What does this even mean?There’s a lot of speculation going on. Beware!
Nothing breaks when you remove it.Its designed to "ramp" in to lock but to break off when removed. It's sloped on the install side but square cut on removal.
DisregardWhat does this even mean?
we found the speculationIts designed to "ramp" in to lock but to break off when removed. It's sloped on the install side but square cut on removal.
