Your sticker says “or”? Mine says “and” which makes sense.Ya, so much for the book. Under the hood says SAE 0W-20 or VW 508. Go figure.
It's so everyone that sees a slight drop in oil level doesn't come in and want a new car. Some consumption especially running a lower grade oil can be perfectly normal under some conditions.Did anybody see this statement? If I had a car that was consuming .5-1qt every 600 miles, I don't know what I would do. Sounds like a major design problem but what do I know. I'm just an IT guy.
Yeah but isn't that amount a little over the top? Maybe it is just me.It's so everyone that sees a slight drop in oil level doesn't come in and want a new car. Some consumption especially running a lower grade oil can be perfectly normal under some conditions.
"&"Your sticker says “or”? Mine says “and” which makes sense.
Ferrari has had that disclaimer in their owners manuals since the late 1970s...I've never experienced oil consumption close to that...but as stated above, I think it is to prevent warranty claims, especially on a transient situation that may be only while the car is still breaking in?Did anybody see this statement? If I had a car that was consuming .5-1qt every 600 miles, I don't know what I would do. Sounds like a major design problem but what do I know. I'm just an IT guy.
I don't want to tell you to not use it but for an Audi/VW, I would use something with the correct add pack which VRP doesn't have. After a quick search, it looks like maybe 502.00/505.00. Maybe try HPL Euro 5W-40. It should clean and/or keep clean while also meeting the visc and VW spec. Amsoil also has their AFL, EFM and EFO. I've used both AFL and EFM in my 2.7t S4.
I get it. I used Rotella T6 in my S and it still runs, though I do have one of the turbos that are blown. I used M1 0W-30 once too. I was running the Amsoil before they had the certs. In the case of the B5 and B6 A4s (I had a bought a used B6 A4), Audi had a lot of problems with sludge and that's why they moved to 5k oil changes from 10k and changed the requirement to synthetic from conventional. It may also be when they came out with the certs too.I hear ya, but honestly HPL is not on Audi's "approved list" either and I don't want an expensive boutique oil. Lets face it, we are not running up over 100 MPH sustained here in the states on our highways, and I'm not doing extended oil changes on the Q7. The oil never gets above 225 oil temp at it highest, more often than that is hovering around 190-200. So honestly what's the importance of running a Euro oil on this engine I'm trying to clean up? So far I've gone from using a quart in 400 miles, to not using any oil at all in almost 900 miles. The engine is not locked up yet, and honestly if I sample the oil on the next change and it show well on the metals and sample, what's the harm? Do I wish it was a 0-40 Euro oil, yes, but its not and I have to believe that 5W-30 will be just fine with oil temps that low. in 2019 Audi recommend to go to a 5-30 anyway with nothing being changed in the engines internals anyway. So I believe it will be OK. If the wear metals turn out to be higher than I like then I'll switch over to Mobile 1 0-40 and just use a can of BG EPR now and again before a change, but I have no intentions of doing that unless the wear metals are to high with the VR&P. Honestly the engine runs really well getting 30 MPG pretty easily, has come to life in the power department and is really running smooth compared to before the piston soak and oil flush.
No but I trust them that they know what they are doing.I hear ya, but honestly HPL is not on Audi's "approved list" either and I don't want an expensive boutique oil. Lets face it, we are not running up over 100 MPH sustained here in the states on our highways, and I'm not doing extended oil changes on the Q7. The oil never gets above 225 oil temp at it highest, more often than that is hovering around 190-200. So honestly what's the importance of running a Euro oil on this engine I'm trying to clean up? So far I've gone from using a quart in 400 miles, to not using any oil at all in almost 900 miles. The engine is not locked up yet, and honestly if I sample the oil on the next change and it show well on the metals and sample, what's the harm? Do I wish it was a 0-40 Euro oil, yes, but its not and I have to believe that 5W-30 will be just fine with oil temps that low. in 2019 Audi recommend to go to a 5-30 anyway with nothing being changed in the engines internals anyway. So I believe it will be OK. If the wear metals turn out to be higher than I like then I'll switch over to Mobile 1 0-40 and just use a can of BG EPR now and again before a change, but I have no intentions of doing that unless the wear metals are to high with the VR&P. Honestly the engine runs really well getting 30 MPG pretty easily, has come to life in the power department and is really running smooth compared to before the piston soak and oil flush.
