Hello folks, Audi A4 Quattro oil change
here i am buying them in bulk from china like a sucker
(i've had an aftermarket oil pan for 2+ years, i just buy m14 copper washers in bulk from china instead)
I too have an aftermarket pan...the Üro Al one so just crush washers now for the mag drain plug and it still gets a weep at the plug...
draining it removes more of the old stuff.
i have the uro steel one with a mk6 gasket. if it leaks i'm putting an OEM plastic one back on.
The Al one is nice because it uses a factory gasket vs. RTV. Threaded drain plug gets a weep that I can't seem to get rid of. May try heavy duty Teflon tape next change.
I’ve got a dipstick on the way, the car is still under its second oil change. The oil is pretty good 4000 miles, I will send an update and pictures on this.
