drained engine oil is red.
There are a few youtube videos on the same subject. It's seems to be something benign that occurs with more than just Valvoline Restore and Protect. Mobil 1 turns red in SD's Honda. It seems to be a benign nothing burger.
if it were my formula I would probably take all additve at 1-2% in base oil and add you used oil to see exactly which one is causeing a color change i would bet on alkaline or acidic additives maybe phenolics also
You drop red liquid in a semi clear to honey colored liquid and it's going to turn red. This isn't any kind of test other than red spreads.
It's as valid as cherry kool-aid turns ginger ale red so there must be something strange going on. No, and diluting cold oil with old cold oil tells you nothing.
This is Mobil 1 0w40 doing some cleaning in an GM 3800 V6. The piston in the middle is partially obstructed by the pickup tube but you can see where the red coloring is coming from. After about 3 more OCI and it stopped coming out with a red hue and was just dark.
This is reassuring that the Valvoline Restore and Protect I'm running that drains red is actually freeing up some deposits somewhere.
screenshot-2026-03-19-at-7-50-22-pm-webp.328999
You can see in this photo it is a little red.
Engine looks clean through the fill hole. Not burning any oil, but it appears Valvoline Restore and Protect is doing something.
What type of vehicle?
You cant go by much through the fill hole, this 3800 was nice and clean up top but it was the underside of the pistons and the ring area that had deposits. I see many Audi 2.0 EA888 engines with super clean top ends but the rings totally seized with carbon up causing it to burn oil like an old frying pan.
Piston soak on these is at best a very temporary band aid when they get this bad, the only real fix is to use the upgraded VW pistons and rings.
May as well throw new bearings, seals, timing chain set and a head job on it while its out.
Yeah it's had a lifetime of bulk oil from the dealer and other quick lube places. Mostly synthetic though. That's why I'm doing 4 OCIs with Valvoline Restore and Protect to get it back to clean.
So true - I have siphoned quite a bit of red ATF out of the PSF reservoir in our Grand Caravan, and replaced it with straw-coloured PSF (Lubegard).
The red colour still dominates.
Thank you to the OP and those who responded. I had this exact thing happen on my 2022 BMW 740i with B58TU engine. I bought the car with ~25K miles. I changed the oil after 1 1/2 years ~3K miles and the oil came out pretty clean looking but definitely reddish brown. I noticed a few drops of similar looking oil on the intake manifold near the oil filter housing that must have been left there from the previous oil change (by the dealer). It occurred to me that it could be coming from the coated connecting bearings...just the upper shell I think...but I thought the engine would have to be at or close to failure for the bearings to be shedding that much bearing coating. I filled the crankcase with Mobil 1 ESP 0W-30...it was normal honey color going in. I don't know what it looks like now...BMW does not believe in dipsticks. I guess I will have to wait until the next oil change...next year.
Thanks again to everyone who responded that the reddish oil is nothing to be concerned about!
BMW oil by Castrol and Castrol most dealers and DIYers like to use makes reddish varnish in the engines. Doesn't hurt anything, but it is very common. I'm in the process of cleaning out 130k miles of Castrol Red out of my X3 with HPL now. The oil under the fil cap was reddish on a rag after 3500 miles.
If oils that clean, come out red, because they are cleaning (possibly harmless) varnish that other oils left behind, I wonder what that red varnish actually is composed of? It must be something (an additive?) that is either in solution in the unused oil, or something that reacts to the conditions in the engine (metals, crankcase vapors, heat?) and attaches itself to the engine internals.
