These front brakes only came on the W8 trim of the B5.5 Passat and are shared with the performance-orientated Audi B5 S4 sedan. Kind of strange calipers with 4 pads per side plus the wear sensor. Previous pads had life but figured I'd change them out as my shop mentioned it last time it was in/state inspection. I had hit the wear sensors a while back so just cut the wires, twisted ends, taped so turn the light on the dash off. Grabbed some Pagid pads from FCP Euro for $115; they should be the same as what came out. Staightfoward change without having to remove the caliper following a good DIY on YT. First side had to fight a bit b/c I didn't know what I was doing but second one went smoothly. Decided against rotors, they have a small lip but are smooth, no need to waste money here, car gets about 3-4K miles a year and already has a high cost-to-operate! Once I got the pads out/compressed the pistons, the caliper slid smoothly so good there. Test drive says success. This car has fantastic brakes.
