You dont want the caliper pin to pogo. If you push the pin in and it "pogos" back out remove lots of lube from the pin and or the bore.
Be sure to burp out any trapped air before declaring there's too much grease.
Yeah, also by aftermarket pin bushings (that rubber sleeve that goes around the leading braking edge pin) were oversized and did not have proper grooves in them so they were acting as a piston.Be sure to burp out any trapped air before declaring there's too much grease.
I’m talking about the Honda M-77 in the Honda tube. AFAIK it is the same as the molykote product, but I can’t say certainly.M77 is $25/1 oz can. IMO, that's a lot. Is it worth the price? Is there another suitable and cheaper than m77 grease you're recommending? I already have the Tribology silicone coming and I'm getting rid of the permatex.
EDIT: it looks like the $25/1 oz can isn't even from Dow Corning, but a knock off itself (Buosha?). The Molykote m77 stuff is obscenely priced $179/500grams. I'm all for spending more if there's value, but that's a bridge too far IMO.
EDIT 2: I'm seeing a Honda 43383-SA5-325 as also being "m77" Is this what you are talking about? It's also around $25 shipped.
Honda M77 is intended for brake jobs. I didn’t say to use it on pins. It’s for other sliding surfaces though.I would forget Hondas miracle paste. It’s meant for splines and such, not brake pins.
Here is a solid option and pretty affordable too. Trav uses it quite heavily and many of us trust his opinion on these things. I’ve used Wurth silicone paste for years with great success, and its similar to this one.
https://a.co/d/crXwxoA
There are different viscosities of silicone greases with different molecular weights of silicone oils. I don’t know what your trilogy grease is compared to the variants the world over uses for brakes. Does it say it’s good for brakes?Thanks. Are you saying I should return the Tribology grease and use this? I also have Dow Corning dielectric grease. I can't link to exactly what I have, but it is similar to DC-4 iirc.
https://www.amazon.com/Dow-Corning-Electrical-Insulating-Compound/dp/B001VXSAI4
IMO there should be a little bit of play, but not like a spring (compressing an air bubble then pushing back out).Yeah when you push them in they should stay at the lowest point you pushed them instead of springing back.
I will take your word for it I am not a mechanic, just a guy trying to keep his rust belt bucket alive.IMO there should be a little bit of play, but not like a spring (compressing an air bubble then pushing back out).
A good clean up is enough, no need to over stress it, otherwise OP may get an idea to use more aggressive abrasives and may enlarge the opening by trying to get rid of the rust.Also your brush should have a drill or an impact driver attachment, rust tends to flake and slough so you will need to go to town on it and hand power is not gonna do it.
I'm going to use a stainless brush that's the same diameter as the ID of the caliper bracket. I'm then going to use a brass brush that's either the same or maybe slightly larger than the ID of the bracket. Final go will be with the nylon brush larger than the ID. I can't see this as leading to much if any dilation of the bracket given my plan. Between all of these, I'm going to be using a ton of brakekleen to wash it out.A good clean up is enough, no need to over stress it, otherwise OP may get an idea to use more aggressive abrasives and may enlarge the opening by trying to get rid of the rust.
Besides, some rust pitting will just hold more grease, so not all is lost.
South Main Auto has very popular brake videos. Here's one for an Odyssey:
This one for a CRV's rear brakes, by TRQ, is also well done:
Permeated meant to say permatex (thanks autocorrect). I can’t edit the post.Gents, thanks for the insight, tips, and product recommendations.
I just redid the job and know it’s done with sound execution and results with solid products. I threw away the permeated stuff and used the white bottled silicone stuff liberally while replacing all the bolts and bolt bushings after a thorough cleaning of the bores with the wire brush kit and gobs of brakekleen. I now have solid experience and kit to draw on going forward. Again, thank you for your help.
Great to hear!!Gents, thanks for the insight, tips, and product recommendations.
Yes. I used some Amazon kit linked in this thread. It was fine. I wasn’t reaming with a bit, and it was the same diameter as the bore so it was fine. A lot of $h*tty stuff came out when I rinsed with brakekleen between drill brush passes.Great to hear!!
So you used the stainless then nylon brushes in the bore? How did that work out?
The Royalty video is excellent and is the procedure I use.You guys have a YT video that describes a “good” brake job? At this point, I’m second guessing everything I’ve done. I’ve seen one from royalty auto care that I thought was good.
Thanks for this. I like Royalty Auto vids and bought their recommended lug brush socket with the pumice-like stuff on the end of it for the hubs when I watched it a while back. I totally forgot about this vid, but remember it now! Good to know about the pin not needing the cap, but I bought new stuff and used silicone grease regardless. I would rather not have to deal with that again bc that was a real b*tch to get out of the caliper bracket! I am optimistic using compatible grease will do the trick this time...hopefully, but time will tell.The Royalty video is excellent and is the procedure I use.
Also, if you can see inside the slider tubes with a mirror, you can see if it is completely clean or not. Of course, it's best to just remove the bracket so you can see inside and clean them out.
Regarding the Honda rubber capped bottom pin, if it is stuck in the tube you can just pull that rubber cap off and still use the pin without a cap (it really isnt necessary). Lots of Honda folks do that when the cap swells, to avoid the pin getting stuck in the future. I used them this way for a few years until the seals got bad, at which point I bought the seal kit and installed new caps.
And Super Lube brake grease works very well.
